g3auto
Jun 10, 2021Tutor
Nighthawk app Error CDIL-API-FAIL
I have an rax15 and am getting CDIL-API-FAIL when try to access the device manager. I am getting the error on both my iPad and iPhone. Have tried reinstalling the app and still get the error. I am on the latest version of firmware V1.0.2.82_2.0.52. I have restarted the router and still have the problem. This has been going on for a few weeks now, any help would be appreciated. Thx
Local wifi? Anywhere Access?
What hardware is this? It may be an R7800, but who knows? I'm afraid the firmware version doesn't help, as Netgear may well use the same number for different devices.
- g3autoTutor
It's an AX1800 WiFi 6 router and I am connecting via local access. I have been able to do this in the past without issue and everything else seems to be working fine.
g3auto wrote:
It's an AX1800 WiFi 6 router ....
Nope. Look at the label on the thing.
AX1800 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. I can see about half a dozen AX1800 in Netgear's repertoire.
- rpmurph8300Apprentice
I am having the same issue with a Netgear RAX50. Running firmware 1.0.3.96 and the mobile app is version 2.11.0.11. This is the first issue i've really had with the RAX50 and the mobile app.
- DarrenMSr. NETGEAR Moderator
I am looking into this issue and will let you know if I find a fix.
DarrenM
- JDaddyGuideSame persistent CDIL-API-FAIL with RAX 20 and the device manager.
- yiyo825Initiate
me too. i'm having the same problem i alreadt contact c/s n tech support but they want me to pay over 100 to assist me.
How did you contact Netgear? Numbers found in a web search are almost certainly take you to a fake website that has stolen Netgear's images.
Invitations to pay money are directed through GearHead, and start at "Only $49.99 per incident*".
This place is free.
