SundeepM
Dec 22, 2020Aspirant
Nighthawk iOS 2.7.2.19 Unable to Rename Devices
Hi All,
I’m unable to rename the device names in the device manager tab of the Nighthawk app !! Also I dont get an option to choose the device icon type, its just as you see in the attached screenshot, just a dotted circle !!
iOS version 2.7.2.19, Attached screen shot for reference.
- Christian_RNETGEAR Employee Retired
Hello SundeepM,
I would recommend checking to see if your device is due for a firmware update along with trying out the Nighthawk admin page via web browser to see if you're able to rename your devices.
Christian
- SundeepMAspirantI figured out the issue is with the router Firmware version V1.1.0.78_1.0.1
Router Model: R6350 (India)
I downgraded the firmware to V1.1.0.64_1.0.1 and then tried opening the Nighthawk app and then the edit option appeared, Upgraded the router firmware and tried checking in Nighthawk app , edit option disappeared.
Netgear support was least helpful and I have reported the same but they are asking everything like logs etc etc of the router even when I have clearly mentioned that the issue is with Router Firmware !!
Not sure how to make them work to fix it ? I would have preferred different brand router
