lucynda's avatar
lucynda
R8000 Netgenie says "router does not support remote access"
Since the net genie update I have not been able to login remotely from my iphone. It says my router does not support remote access but I know this is not true as I used it remotely ALL the time with the previous app. How do I fix this??? I need to be able to block/unblock access to wifi on my kids devices when I'm not home.
  • FURRYe38's avatar
    Was the routers FW updated? Is remote access enabled ON the router using the routers web page?
  • I updated the firmware - still didn't work. Rolled back to the firmware recommend on another post. Still nothing
    Yes it's turned on in my router settings
    • FURRYe38's avatar
      Try removing the app from the phone, power cycle the phone then re-install the app.
      If this fails, I'd phone contact or send a ticket about this to support. Something isn't right here.
    • FURRYe38's avatar
      Go to the NG site and select support. I believe there should be some information there to either phone or create a ticket.
  • To call them it costs more money than I can afford
    Starting at $49.99
    I can't find anywhere to send an email
