Resmithn's avatar
Oct 23, 2017
ReadyShare Vault Service will not run
Installed Windows 10 Fall Update. ReadyShare Vault service [GenieTimelineService.exe] will not run. Faulting module is GSWatcher4.dll.
Have another PC [w/o Windows Fall Update] ReadyShare Vault running okay. Attached file is Windows event log.
Appreciate any feedback.
Thank You
  • Netgear support was awful. They wanted $150 since the "90 days" expired. Submitted to Genie9, their reply is below.
    New reply for the ticket #GTLSup00181350
    Hello Robert,
    Regarding your issue, we're well aware of this problem as it has been caused by the latest update of Windows 10. Unfortunately we couldn't solve the issue on the 2016 version. However, our 2017 doesn't have this problem and it can be downloaded from the following link :
    http://www.genie9.com/business/Genie_Timeline_pro/download.aspx
    If you wish to purchase it, please note that we're running a 50% discount which can be claimed from the following link :
    http://www.genie9.com/promo/Genie9OffersHalloween.aspx?utm_source=halloween_offer&utm_medium=genie9_email&utm_campaign=23_10_2017
    Thomas Parker
    Genie9 Technical support team
    Genie9, Backup redefined
    #GTLSup00181350
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Resmithn,
      1. Have you tried re-installing the program on the computer experiencing the issue?
      2. Only the ReadySHARE Vault program that can be downloaded from the official NETGEAR page linked below is supported.
      http://netgear.com/readyshare
      Dexter
      Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Resmithn,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • Resmithn's avatar
        Resmithn
        Tutor
        No, as said I downloaded Genie Timeline per thread above. ReadyShareVault will not run on PC with Windows Fall update installed.
