growlf
Jun 05, 2021Initiate
Meural Software - Crap support, crap developers
So Netgear sells a product that is dependent on software, pushes out software updates, and provides ZERO support for the software - awesome - what a craptastic company.
First issue - Light detection has been borked for several updates. Gave up, wrote my own to sit on a raspberry Pi and update the canvas brightness properly.
Second issue - and this is a big one - some update has added auto-sleep and auto-power off settings. Cool. Mine are in continuous display mode on a wall about 20 feet off of the ground. Imagine my surprise when, after a recent update, all three frames popped up with a message saying they were shutting down.
That message stayed on the screen for at least 2 hours until I cut power to all of them. (Photo of one of them w/ the message attached.)
They rebooted fine, but this morning, they were all offline and shut down. (They sleep at 9pm.)
I've now toggled the power mode to "sleep" on all of them, then back to "continuous display mode." I've also reset the schedule and rebuilt it on all three canvases.
If, tomorrow morning, they are all shutdown again, I'm going to be pissed.
If *one* canvas had an issue, fine. All three tells me that this is some stupid software issue that shouldn't have made it into production. Yes, I write better software than this, and I've mostly rewritten all of the canvas functionality so that it works properly with my own apps. What I can't do is magically fix the devices from shutting down. Hitting a power button 20 feet off of the floor is a problem.
Does this sound angry? Yup. That's $2k worth of screens on my wall, a subscription I pay for - and Netgear should have to support the damned software they write and push out.
- Christian_RNETGEAR Employee Retired
Hello growlf,
I'd like to look into this further and address your concerns. May you send me a private message with your email address and serial number.
Thanks,Christian
- iklierInitiate
The latest FW (2.2.10_2.0.13) is super buggy for me as well. The three things that broke for me were:
1. Auto-sleep on low light (was working in previous firmware and now is completely broken)
2. Auto brightness (this was always a bit buggy, but seems flat out broke in the new FW)
3. Album switching was buggy for a bit post-update, but a power cycle seems to have solved the issue.
EDIT: math is hard.
Hello iklier,
Thanks,Christian
- pbellardTutor
I have the same problem with my Canvas, any firmware update to address these bugs?
