Retired_Member's avatar
Retired_Member
Aug 16, 2021
Accidently updated the router before satellite on MK63
According to this web page:
https://kb.netgear.com/000063806/MR60-MS60-Firmware-Version-V1-0-6-112-Hot-Fix
I'm suppose to update MS (satellite) first then MR (router) second.
As the title said i accidently updated the router before satelite.
Currently under router update tap.
MR60 firmware is v1.0.6.112 (latest)
But both satellie 1 and 2 firmware is still v1.0.6.102 (08/12/2020 relase)
I've been trying to update the satelites with MS60-V1.0.6.112_2.0.52chk and they fail everytime.
Everything seems to work ok so far, but would like to both MS satellite updated to the latest firmware as MR.
Please advise.
Thank you.
  • Retired_Member's avatar
    Retired_Member
    Aug 24, 2021
    It looks so simple when it works, wow! I'll have to start using FF from here on.
  • FURRYe38's avatar
    You need to update the RBS before updating the RBR. Keep this in mind for future updates.
    See if this process works for the MK series as it works for Orbi systems:
    What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
    Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
      Retired_Member
      Thanks FURRYe38 for reply,
      Will try this option and will report back.
      Retired_Member
      After factory reset the RBS and log in as admin and password (default) and the update is completed.
      Do i need to change password on RBS from default to match RBR prior syncing?
      • FURRYe38's avatar
        Good to hear. No, just re-sync the RBS to the RBR and it should acquire the data it needs.
