Ian57
Jan 04, 2022Follower
Blinking white light for MS60
Had 2 full M60 systems. Both routers setup, 1 as an AP. 3 of the 4 sats setup around the house. Yesterday I had to reboot main router and even factory rest it. Today it all crashed, nothing worked. I ended up doing a full reset and setup of the main router. Some of the sats will connect but the AP router just blinks white.
- Rebooted at least 10 times
- Sync'd
- Factory reset button
Nothing will get it off that blinking white light. I believe trying to resolve the issues yesterday I got it out of AP mode and into bridge mode or it simply is just stuck as AP mode but with a conflicting IP.
Note: my phone shows a NETGEAR_SETUP as an open network. This was not there 2 days ago. I assumed I needed to connect to that so I could then edit the IP and/or settings for the AP router. It never connects, spins and finally says...IP address Failure. Again leads me to believe it has conflicting IP with the main router.
I need to find out how to fully factory reset this thing, then I should be able to hook it up, login, and make the changes i need to put it back as AP router. If I can't am I just stuck with a dead weight?
Any suggestions greatly appreciated.
So lets try setting up just 1 MK system while leaving the 2nd OFF.
Try to Sync the MS near or in same room as the MR.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- je13air47Aspirant
This KB worked for me, it was a little annoying, but the tech I had was patient. After we tried all the standards, this was finally the one that got it going.
- dmsaeAspirant
je13air47's method fixed my problem. I had blinking white lights on all satellites after attempting a FW update through the Nighthawk mobile app. I tried power cycling and hard resets, but none of that fixed the problem. I'm not hardware savvy, so I was reluctant to push a FW update through a hardwired connection, but I followed the instructions exactly, and now my my mesh network is working again.
Any progress on this?
- Sync'd
- nynexlaAspirant
Mine is now doing the Blinking White thing. I've tried resetting many many times , and all the TFTP the firmware updating and everything it just wont connect. My 2nd failed nighthawk device. Lessons are learned.
