Cinji18
Oct 09, 2023Aspirant
MK63: Not getting Internet connection even thought the indicator light is solid blue
MK63 (AX1800)
The router has a solid blue light, but I am not getting any Internet connection on any devices.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many MS are deployed?What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network. - michaelkenwardGuru - Experienced User
Cinji18 wrote:
The router has a solid blue light, but I am not getting any Internet connection on any devices.Before diving off into arcane territory, start simple and tell people a bit more. I'm afraid things like "it doesn't work" provide few diagnostic clues.
Are these wired or wifi connections?
What happens when you try to connect? Any error messages?
Can wifi clients see the SSID broadcasts from the MR60 and/or MS60?
What modem, ONT, gateway sits between the MR60 and the Internet?
- Cinji18AspirantI'm not sure where the error messages are showing up. I just know my devices say no Internet or their lights are telling me they are not connecting.
What is SSID? What is MR60 or MS60?- FURRYe38Guru - Experienced User
SSID is the wifi service ID name of the wifi broadcast that comes from the MR and MS satellites.
MR is the router base unit, MS are the remote satellite units.
