meepadoo
Jan 15, 2023Aspirant
MS60 Offline with Blinking White Light
I have an MR60 router with two MS60 satellites. One of the satellites has gone offline and has a blinking white light. I have tried cycling the power. Additional troubleshooting steps are appreciated, thank you.
meepadoo wrote:
I have an MR60 router with two MS60 satellites. One of the satellites has gone offline and has a blinking white light. I have tried cycling the power. Additional troubleshooting steps are appreciated, thank you.Have you tried a factory reset of the satellite followed by a reinstall?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- meepadooAspirant
michaelkenward Thank you for the suggestions. I accessed the user manual and found instructions on how to perform a factory reset. I pushed the reset button on the back of the satellite with an audible "click" for at least 5 seconds (I actually held it down for 10 seconds) while it was plugged in. The white light never stopped blinking. Is the led indicator light supposed to signal a change and reboot when performing a factory reset?
Was the MR updated recently?
What FW is currently loaded on the MR? Possible the MR was updated with out the MS being updated. FW versions have to be the same for both. The MS should be updated first the MR lastly.
Try connecting the MS via ethernet to the back of the MR and see if it will sync.- meepadooAspirant
FURRYe38 the firmware currently installed on the MR is V1.1.7.132. I have never manually updated the firmware. Apologies if that was something I'm supposed to do regularly. I thought it updated automatically.
I have connected the MS to the MR via ethernet per your suggestion. I pressed the sync button on the MR and the led changed from solid blue to a faster blinking white. I then pressed the sync button on the MS (also tried holding it down for 5 seconds) but the MS led never changed from a slower blinking white, even after the MR changed back to a solid blue light, and the MS in question still shows not connected in the Nighthawk app.
I'll appreciate any other suggestions you might have.
Ya we see sometimes that the auto update doesn't update the MS properly or before the MR.
Do you see the MS in the MRs web page under connected devices and does it report have an IP address there? If so, you can log into the MS web page using the IP address to check it's FW version and if it's not updated, manually update the MS by sending the FW file to the MS directly thru its web page.
Also there is newer FW available as well:
Users reported seeing issues with v.132 so you might want to update to v.134 on the MS first, then MR lastly.
