ketachicken
May 10, 2022Aspirant
Netgear Nighthawk MK models can only access Google/Facebook, but not for other sites.
I have been using the MK62 since 2020. This problem start popping up when I switched my service provider this month.
Occasionally, I will lose access to all websites, except for Facebook, Google, Youtube (they will work perfectly fine). The light icon on MK62 will remain blue during the issue occurs. Everything will go back to normal when I remove the power plug and reset the router.
Also confirmed that the modem is working fine during the issue occurs.
Anyone has faced similar issues? Is it related to the firmware updates this month?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- ketachickenAspirant
My Firmware version is V1.1.6.122_2.0.58.
ONT model no. is G-240G-E by Nokia. It is connected to another router provided by local Internet Service Provider (confirmed that this router has no connection issues when the situation occurs).
Did several resets since last update.
so you're going the nokia---->other router-----MK nighthawk?
That can cause a double nat and issues.
why are you using the other router?
Is it in passthrough/modem only mode?
Or have you put the MK nighthawks iP address into the other routers dmz?
