HiImBarryScott's avatar
Mar 31, 2018
Cannot get network prioritisation to work properly (XR500)
Hi everyone,
I recently bought a XR500 Nighthawk gaming router. I cannot however get the network traffic prioritisation to work properly. Sometimes it picks up game traffic (Blizzard launcher) but then it turns off when actually playing a game (World of Warcraft). Some games it doesn't even pick up at all (Battlefield 1, 2 & 3; Call of Duty: WWII). I've tried automatic by enabling the "DumaOS Classified Games" option via the associated checkbox. I've also tried adding devices/profiles but that doesn't seem to work either. I've also tried manually entering ports, but get an error message saying that they overlap with another profile. There are some prioritised packets but hardly any at all (~150 out of ~500k).
I've also applied anti-bufferbloat and capped it at 75% for both upload and download. As far as bandwidth allocation goes, that's also at 75% for upload and download for my PC and 25% for upload and download assigned to my smartphone. I also have the geo-filter enabled, based in the UK and set to 1400km in filter mode (profile is for Call of Duty).
My current setup network wise is I have a BT home hub 5 (an awful piece of equipment I know) setup as an access point. I have the XR500 WAN port connected to the BT router via a LAN socket. This setup will change in the future though when HyperOptic get back to me about why my 1Gbit/s fibre only has a download speed of 5Mbit/s. When that's sorted I'll put the HyperOptic router in modem mode and use that instead.
Any help is much appreciated! If you need any more information then please feel free to ask.
Thanks in advance!
  • priority packets not woking for PC battfield 1
    i have called and went through all options ports dont work either
  • Hi there - thanks for all the info. Very useful explanation.
    From everything you have said, your Geo-Filter and Bandwidth Allocation settings are great. So there’s two things I recommend you do:
    1. Traffic Prio - this works by detecting when a console is being played, or when a PC game is being played. It just prioritises those packets. So your CoD game should be fine, but it’s likely WoW is not being detected. Could you clear all the port rules you have added and start again. First, make sure DumaOS Classified games is checked. This will catch most games. Now add the ports for WoW.
    After doing this, check that the red light comes on next to ‘High Priority Traffic Detected’ and packets increase. If they’re not, then it means you probably have not added the correct port.
    If this is not happening let us know the game you are playing and the ports you have added.
    If the overlap issue occurs again, could you also let us know which ports you have added
    2. Secondly, and much easier this time, set Anti-Bufferbloat to the mode ‘Always’ when you’re playing, and Never when you’re not. Once we figure out the Traffic Prioritization issue you can then use the more convenient ‘High Priority Traffic Detected’ mode
    • HiImBarryScott's avatar
      HiImBarryScott
      Hi Netduma_Jack,
      Thanks for getting back to me so quickly. Apologies, I should've mentioned that I had already set the anti-bufferbloat to "Always".
      As for the priority stuff I deleted all the rules I had set up. I've also added custom ports for World of Warcraft.
      I've also added the recommended ports for Steam (which include the ports needed for Call of Duty: WWII; which I play via Steam).
      I have port fowarding set up for the steam ports, but not the WoW ports.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Great that sounds like it should work just fine, have you confirmed High Priority Traffic works now?
