blaisual's avatar
May 09, 2021
geofilter fail xr500 destiny
i have the firmware xr500 v2.3.2.114 but the geofilter does not working on the game destiny 2,does someone have a solution or know howto fix it. have already tried a lot and tried but nothing worked and no flush cloud.the flush cloud says thatR-app will not work for a certain period of time.
please help.
  • We have recently pushed an update for Destiny so you should be able to filter by servers now. We are aware that there appear to be a couple of authentication servers that can still be blocked so you may need to manually allow any 'blocked' connections that appear in Geo-filter when you try to find a game. Once we've pushed a new cloud update, you shouldn't need to do this.
    Also, the error you're seeing in Ping Heatmap is normal, it will have successfully sync'd with the cloud, it just threw an error becaues it took a bit longer than it was expecting.
    • Dunaz's avatar
      Dunaz
      Guide
      Come faccio a capire se il mio xr500 blocca i server, sembra che continua a ignorare geofilter, guida i alla soluzione grazie
    • Malver's avatar
      Malver
      Liam, ese par de servidores a los que haces referencia permiten bloquear jugadores fuera de rango en destiny 2 como antes de la actualización? donde estan situados estos servidores para probar el geofiltro?
      Muchas gracias.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        Ya no creo que puedas bloquear a jugadores específicos con DumaOS solo, ya que Destiny ahora se ha movido al emparejamiento basado en servidor y no de igual a igual.
