SuicideSquad420
Apr 07, 2022Apprentice
netgear xr1000 gaming router
so i updated the xr1000 to the newest firmware in for some reason i keep getting a error code Uncaught TypeError: $(...)[0].getApp is not a function everytime i log into the router in sometimes it takes forever for it to even load. please look into thank you.
- Netduma-FraserNetDuma PartnerIf you haven't already it is recommended to do a factory reset after an update to ensure no issues carry over from the previous version, I suspect if you do so the issue will be resolved.
- SuicideSquad420Apprentice
so i did what u said in still getting the same error code Uncaught TypeError: $(...)[0].getApp in it still taking forever to load even after reset you all gotta loook into it. with this new update.
- Netduma-LiamNetDuma Partner
Could you please clear your browsers cache now and that should then clear it for you.
As above, please factory reset the XR1000 after installing the firmware and clear your browsers cache.
- SKWildCatAspirant
Uncaught TypeError: $(...)[0].getApp is not a function, Problem I have a problem what to do
so now im getting a error code when trying to log into the router now starting to be weird ever since i updated to the newest update i had have problems with this router the error im getting now tho is haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
