FURRYe38's avatar
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
  • Supports DumaOS 3.0 features.
Security Fixes:
This article applies to:
Nighthawk Pro Gaming (1)
Let us know how it works for you...
  • Buenas tardes, con la ultima actualizacion , despues de haber restaurado de fabrica el router xr500 , cual seria la configuracion optima para poder jugar con mi ps5 en el Qos??? si lo pongo en automatico , la red de mi casa se viene abajo y no funcionan ni los dispositivos wifi.
    Gracias
    • FURRYe38's avatar
      In inglese per favore
      Gracias
      • aaronibm21's avatar
        aaronibm21
        Luminary
        Good afternoon, with the latest update, after having restored the xr500 router from the factory, what would be the optimal configuration to be able to play with my ps5 in Qos ??? If I put it on automatic, my home network breaks down and not even the Wi-Fi devices work.
        Thanks
  • Hi Netgear Support,
    Do you know if there are any plans for future firmware upgrades to add the ability to define a DHCP lease duration time?
    XR450, Firmware 2.3.2.130, OS Win 10 Home
    -Kevin_N
  • After going to the .120 beta, factory resetting, upgrading to .130, factory resetting, everything seems to be working except for traffic prioritization. When I go into QOS, i just get a pop-up notification saying that 'Device is not found' and the traffic prioritization never populates, just stays in the loading state.
    • DredPirate13's avatar
      DredPirate13
      Apprentice
      Actually, it's not working even when I factory reset on .120.
        DredPirate13
        Apprentice
        What I figured out that I needed to do was revert back to the system provided .114 firmware update, then factory reset, then update right to firmware .130 and it seems to work fine now. I haven't factory reset due to the known issues so I will just backup my settings and wait for the next firmeware update.
  • Hi all... any update on when we can expect to get an updated firmware from netgear that fixes these issues regarding DHCP/router dropouts?
    Also would appreciate if anybody could explain how to revert the software back to the original software provided with the router or an earlier version before these issues started occuring and provide a link to it please.
    Been unable to use my XR500 these past couple of months.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      We're waiting on NG to test and give the go ahead for our changes, unsure whether it will feature their fix, it should do.
      Download the relevant firmware from the support site then downgrade in the way that you upgrade by uploading the file .56 may work but do keep in mind you will lose security updates by downgrading.
      https://kb.netgear.com/000061157/XR500-Firmware-Version-2-3-2-56
      • mathmath51's avatar
        mathmath51
        Apprentice
        Hi,
        Any news regarding the next versionof the firmware, or at least some confirmation of the DHCP bug will be fixed ?
        Thanks
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      We don't have a specific date yet I'm afraid, although I can confirm we've recently been working on new firmware for the XR1000 and are testing it currently.
      • Raf1212's avatar
        Raf1212
        Apprentice
        and then nothing, probably remote work, another month of waiting for a new beta version
  • Retired_Member's avatar
    Retired_Member
    I have the XR 450. Is there a new update for the beta yet?
