MRS911's avatar
MRS911
Guide
Apr 16, 2020
open ports on xr500
hello
i want ask about open ports on xr500 for ps4 ,
i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
  • Firstly what is your physical setup? UPnP should be able to open the ports without using the DMZ or port forwarding. How are you determining the NAT type?
    • MRS911's avatar
      MRS911
      Guide
      I used bridge mode from ISP router ,,
      I didn’t find upnp to open the ports well, because I tried that with cod:MW game and it appears to me that Nat modraete , UPNP only open one ports 3659 UDP !!
      If i enabled DMZ the NAT is open but i have bad experience with it .
      so now i will try to open ports but i dont know how ??
      by Port Forwarding or Port Triggering ?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        If you disable the Geo-Filter before turning on the console does it appear open? Sometimes the Geo-Filter can cause a misreading.
  • FURRYe38's avatar
    Are you sure the ISP modem is fully bridged? The Internet WAN port address will show a ##.##.###.### kind of address if it's fully bridged.
    This a PC or game console?
    What is the port being seen and used by the console if you have a game console. It should be 3074.
    Do not use DMZ for your game device. uPnP is only needed. If you only have 1 PC or gameconsole and NAT is single at the XR router and the modem is fully bridged, OPEN NAT should be seen in the game and xbox networking settings.
    • MRS911's avatar
      MRS911
      Guide
      my ISP router model huawei HG8245Q
      actully i dont know if bridged with ISP router well , he give me public ip and its work with PPPOE in xr500 ,, but maybe need some settings with bridge mode from isp router .
      there is only one port i see on ps4 IP in UPNP : 3659 UDP !!
      if i used UPNP the NAT with call of duty:MW game on ps4 is moderate
