DylanK
Aug 10, 2022Tutor
Unable to Edit/Delete Traffic Controller rules
Is this fixed yet?
- Netduma-FraserNetDuma PartnerI don't think anyone has brought up this issue before, what happens exactly when you try to delete a rule?
- DylanKTutor
After doing the factory reset from GUI (not using pushing the pin from physical router), the rules dont show up.
As you can see here, I can see that the rules are there from traffic analytics but under the rules nothing show up.
Log shows:
[DumaOS] RPC call 'get_device' exception 'ERROR: Nonexistent device stack traceback: ^I?: in function '__new__' ^I?: in functio,
[DumaOS] RPC call 'get_device' exception 'ERROR: Nonexistent device stack traceback: ^I?: in function '__new__' ^I?: in functio,- Netduma-FraserNetDuma PartnerWhen you do a factory reset it wipes settings as though you were setting it up from scratch so that is normal. The log entries don't necessarily refer to Traffic Controller specifically.
What FW version is currently loaded?
What browser are you using? Happens in different browsers?
- DylanKTutor
2.3.2.134
The browser I used are chrome and firefox and both shows same problem.
- Netduma-FraserNetDuma PartnerDid the physical factory reset wipe it properly this time?
