Taurus2313
Nov 29, 2022Guide
XR1000 Connection issues-Please help!
Okay I posted in another forum but it got no responses at all. I don't know what else I need to do. I have been having an issue with this router for week now.
I keep getting "cannot obtain IP address" for my wireless devices. I have power cycled my entire system (Modem and Router) hundreds of times (over a week now) and factory reset the router many times as well too but still I have this same issue. If I leave the factory SSID in place everything works fine for a while but once I change the SSID of the 2.4ghz band where all my devices are connected back to the one I created for them, 1 year 9 months ago it totally wipes out any connection to both 2.4ghz and 5ghz bands. I get the dreaded "cannot obtain IP address" across the board for anything that is connected via Wi-Fi.
Hardwired devices sometimes work and sometimes not. It is like it is all over the place. I have NEVER seen or went through anything like this with a router before. I have discussions with my ISP, I have had discussions with Netgear support and still cannot get this issue resolved. Netgear support closed my ticket due to it being out of warranty. So now I am stuck like chuck!
Today I decided to do another factory reset on the XR1000 because my system went down again and it asked me for the Fixed IP address setting from my ISP. It has never asked me for that info before. I don't know what those numbers are so I cancelled the setup and did a chat with Xfinity to hopefully get them. They would not give them to me and kept saying that I had to contact ARRIS for that info. It seems I am stuck in an endless loop of getting nowhere. I am desperate. What else can I do at this point? I am trying to salvage and not replace this router.. I have come here for help or ideas as to what is causing this issue. Surely someone has some insight on what is causing this or what I need to do. I would appreciate any advice..
Modem standalone works fine. No Issues. XR1000 has latest firmware update.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Most ISPs use DHCP for the WAN side so no FIXED IP configurations are not needed here from the ISP. Check with the ISP if you need to see if this is required by them.Your model Arris model will be telling as well.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
- Netduma-FraserNetDuma PartnerGood advice above. In regards to the WiFi issue, could you clarify please? So you have the default SSID e.g. Netgear 26 that all devices are connected to, then you change the SSID e.g Taurus WiFi then they don't get an IP? Did you re-connect the devices to the new WiFi? Even though it may be the same name as what was used years ago, the information may have changed such as the security method so you would need to connect them again.
On the 2.4ghz band if I change that from the factory name & password SSID to the one that I have been using for the past 1yr 9 months then yes whenever the devices come online to connect to that 2.4ghz SSID it knock everything offline and I get the cannot obtain IP address issue across the board for both Wi-Fi 2.4ghz and 5ghz bands..
Yes the one day I was able to get everything back up and going again I did have to update every 2.4ghz controlled device (Bulbs, Plugs, Cameras etc..) to the SSID all over again and it was an utter pain to do that. It took me almost all day to get it done and that is using the same SSID that they are tethered to for the past 1yr 9months..
After changing from the factory one back to the one I had been using. I hope that this makes sense..
- Netduma-FraserNetDuma PartnerCould you provide the SSID name you're using or if you're not comfortable with that, is it just alphanumeric or are you using symbols in the name as well? If you are using symbols, what symbols are you using?
I am so sorry. I did try to reply to your post like 3 times and it would say that it posted but it never did. Going to try to answer your questions again..
Firmware version is latest one 1.0.0.64 -Whenever doing a factory reset upon completion of the registration it would automatically check the router for the current firmware version and update it if needed so I was running the current updated one.
Stand alone modem is an AARIS SB8200 and I have been using Cat7 cables ever since I had this setup in 2/2021.
In short I had done everything that you had suggested already with the exception of changing the DHCP IP address pool range. Once I was finally able after many more attempts to get the router registered and going I did go into the settings and change the numbers to the ones that you suggested and so far it has not dropped off.
