DK350Z's avatar
DK350Z
Star
Jun 15, 2021
XR1000 DumaOS not loaded yet!
Hi,
Firstly sorry if this has been answered before, however I have searched this forum and have not found a 'stable' solution.
I purchased a XR1000 a while ago and appeared to set it up without problems. I changed the SSID and password to match my old R7000 router to make setup easier (and I don't have access to my soler inverter and battery to connect them to a new SSID). Throughout the setup I was able to see the DumaOS with my browser, and it loaded after I had completed the setup.
Later I tried to login and it came up with the message DumaOS not loaded yet! (image attached). I tired using default gateway IP (192.168.1.1) and routerlogin.net, neither worked. I tried using Chrome and Edge, and still the same message. I restarted the router, no change. Finally, as a last resort I tired resetting the Routing (holding for 30 seconds). Again I went through the entire setup, changed SSID/password, and DumaOS was accessible again hooray! However, the next day I get the same message "DumaOS not loaded yet!" I have not been able to access the DumaOS for at least a month now.
As a temporary workaround, I can access limited functionality through my Nighthawk app, and I can access the router through a browser using http://routerlogin.net/adv_index.htm, however this also appears to have limited functionality.
My firmware version is 1.0.0.52. I believe I started at an earlier version, but the problems started before I updated, I think.
  • Sorry to hear this, could you please try going to System Information -> Installed Rapps -> Click the three-line menu and change the number of retries to 5?
    You may need to reboot the router after this, then let us know how you get on!
  • Hi Netduma-Fraser and Netduma-Liam,
    Ok so I've factory reset both my Modem and XR1000. I then put the Modem back into Bridge mode, the XR is connected via LAN port. I then logged into XR successfully, completed setup and arrived to the DumaOS, Yeh! :-) I have gone to System Information -> Installed Rapps, and set retry attempts to 5. Restarted, waited about 3 minutes, logged back in and DumaOS is still working.
    I'll monitor tonight and over the next couple of days to confirm it still works.
    Thank you so much to you both for the support, very much appreciated!
      • DK350Z's avatar
        DK350Z
        Star
        It's been a couple of days now, and unfortunnately I'm back to the beginning with "DumaOS not loaded yet!" showing up when I try to enter the webpage :(
        I have tried Chrome and Edge, and I've cleared the browsers cache and I have rebooted the router, still no change. I'm not sure what else to try
  • I also have the exact same problem with my router. it doesn't have anything to do with the modem(mine is the matching netgear pro gaming modem that matches the router in performance), it isn't even close to a modem problem. it is 100% the routers DumaOS system not working. it has done this for months off and on. with one error loading message to the next. except this time it actually has a message telling you its not loading, before it just didn't load and then refused to even pop up the admin login window anymore.
    i have tried everything, from factory resetting, to contacting internet support (everythings fine on our end) is all i ever get told. it is a router issue that needs addressed
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      The router is a standalone device so nothing else would be affecting whether it can load correctly or not, go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
      • iTzPookie's avatar
        iTzPookie
        Tutor
        sorry, i replied in the wrong chat.
        i don't know what you're talking about when you mention system information page and rapp panel. i can not access the router at all.. so I'm confussed.
