MJMasters1234
Jun 30, 2019Aspirant
XR500 - Unable to configure product due to router keeps disconnecting from browser
I have just purchase this product and am unable to stay logged into router via web browser to configure
What is the Mfr and model# of the ISP modem the NG router is connected too?Be sure you are wired to the back the router with a PC.
Try a different browser, FireFox or Opera.
- MJMasters1234Aspirant
The latest firmware, unable to confirm firmaware details as uanble to log on.
Virgin media superhub in Modem Mode
tried wire connection no difference
- Netduma-FraserNetDuma PartnerWhat happens when you try to login? Are you using the details set in the setup wizard?
- Xr500Apprentice
The XR500, when I first sold it, I bought it, and until now its network disconnection problem has not been completely fixed. :smileysad:
- Netduma_AlexNetDuma Partner
Are you on the latest firmware?
- Xr500Apprentice
yes
Have you tried a different PC to see if this problem follows?
Please downgrade to v32 and see if this changes anything. Seems like this maybe a PC issue rather then router issue as others have not posted about this. Possible the router could be faulty.
- Xr500Apprentice
When the router is disconnected, two iPhones 8 can connect to wifi, but they can't use the Internet.
Other PCs and laptops will be affected. I don't think it has much to do with PCs.
Have you tried the hotfix firmware?
https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
