Sidz_Gaming_
Jan 26, 2022Guide
XR500 DAILY INTERNET DROPS
XR500 FW 2.3.2.130
Hello all this is my 1st post to please bare with me
i bought my xr500 (XRM570) and i have been having issues ever since i set it up, internet drops i thought it was my ISP so had them come out a numoruse of time, but i really do think its the router, after reading up on the issue i have seen i am not the only one, every time the internet drops it always have renew lease in the logs, today i tried for the 1st time while the XR500 was down try using my isp router and it worked, so it must be the XR500
netgear support have been no help at all, i finaly get an email saying they are going to issue me an RMA (replacement) but then they close the case and no reply, i really dont know what to do anymore my house secuirty is internet based so i rely on the internet working more. i bought this router so i could have better internet but at the minute feel like i have boight an expensive paper weight.
Can anyone please help me or put me in contact with somone that could help
Hello I know it’s been 3 years, did they ever sort this issue with internet drops, I am thinking of using this router at my in-laws but was just wondering did they fix it, thanks
I only saw this once with my XR500. When I used default DHCP IP address configuration. Once I changed to using .100 to .200, never saw it again.
- Netduma-FraserNetDuma Partner
I don't know that there has been a specific firmware fix for it but I can tell you that I've definitely not heard of the issue happening as much on later firmware versions and if it does then the advice in this topic almost always resolves it.
- Netduma-FraserNetDuma PartnerSet the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
Netduma-Fraser are those IP ranges specific? I really don't want to reconfigure the whole house (reserved addresses are between 50 and 119) to eventually get a workaround..
I'd rather set the DHCP range to > 120 if that's an option and leave reserved adresses as-is..
- Netduma-FraserNetDuma PartnersteiNetti No it's not specific, as long as you have reserved IP address outside of the DHCP range then that is the main thing to help prevent the issue.
most of my devices i have put in the Address Reservation but will try this, when the internet goes completely down i can not even acsess the routers page
ps. my computer is hard wired
thank you
- Netduma-FraserNetDuma PartnerIt is a known issue unfortunately but hopefully by doing that step it will reduce the frequency
