Marv-K's avatar
Marv-K
Guide
Feb 05, 2023
XR500 Geofilter Problem Ps5
Hallo ich habe eine Frage bzw ein Problem. Ich nutze VPN (keepsolid open vpn) und den Geofilter . Aber ich finde ohne Crossplay keine Spiele.Natürlich habe ich den Geofilter richtig eingestellt . Habe den Geofilter vor und nach Spielstart aktiviert. Es ging beides nicht. Cloud habe ich auch neu Synchronisiert. Mir werden nur bei Spielestart ganz kurz alle Server angezeigt jedoch verschwinden dann alle wieder.
Hello, I have a question or a problem. I use VPN (keepsolid open vpn) and the geofilter. But I can't find any games without crossplay, which I don't understand. My real location is Europe and I have activated New York as my VPN location. As soon as I turn off crossplay, I can't find any games. And if I just use the geofilter and select the North America region, I still don't ping those servers. I do not get it. Please help.Of course I set the geofilter correctly. Activated the geofilter before and after game start. Neither was possible. I also resynced the cloud. All servers are only briefly displayed when the game starts, but then they all disappear again.
  • If you could just join a game as a test then take the screenshot that would indicate what is happening. It's hard to say without seeing exactly what is happening, it could be a server is incorrectly whitelisted for example which we could fix with a cloud update
  • Without the VPN do this to try for New York.Try this:
    Quit the application/game/client completely
    Remove device from the Geo-Filter
    Give PC PlayStation Device Type in the Device Manager (if on PC)
    Resync from the Geo-Filter Map menu
    Re-add the device to the Geo-Filter with the manual option
    Set up the Geo-Filter how you like
    Wait 2 minutes
    Boot up application/game/client
    Then see if it works better.
    • Marv-K's avatar
      Marv-K
      Guide
      I've tried that many times. As soon as I only use the geofilter it doesn't work at all. The ping doesn't change there and I find the same lobbies as without the geofilter. Very annoying, unfortunately..
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Can you provide a screenshot of the Geo-Filter page when you're getting the same games as usual? What do you mean 3 PlayStation options?
    • Marv-K's avatar
      Marv-K
      Guide
      In addition, I am shown 3 * Playstation options where I could filter. You have to try it first to know which is the right device.
