jteagles's avatar
Nov 21, 2018
XR500 Internet speed Problem
Hey guys,
Since Ive started using the XR500 my internet speed has nearly been cut in half.I was getting 75-80 mbps with the isp router but now Im getting around 45.Ive disabled Qos, Ive tried the modem in router+modem mode and modem only mode, basically Ive tried everything Ive found on this site from people with the same problem.Has anyone solved this problem that I might have missed?
Btw Im using the DM200 in modem+router mode with the XR500.I did try the DM200 on its own without the XR500 and was getting around 33mbps.
  • Hi - it sounds like you may have a problem elsewhere if you're getting just 33mbps into the modem. Are you able to switch your ISP modem back in and then connect your XR500 to that? You should hopefully be back to full speeds then.
    • rakano77's avatar
      rakano77
      Hi - it sounds like you may have a problem elsewhere if you're getting just 33mbps into the modem. Are you able to switch your ISP modem back in and then connect your XR500 to that? You should hopefully be back to full speeds then. DigitalOcean  SiteGround iPage
