Intmedhead8's avatar
Sep 11, 2020
Orbi RBK 853 speed test not working
Speed test is no longer working. States connection failure. I have rebooted and uninstalled and re-installed my APP. No luck. It was as working when I first got my mesh in June and now that my free Netgear support has expired, it no longer works. Coincidence? Had anyone had this recent problem?
  • Fritzsche0529's avatar
    Fritzsche0529
    Sep 24, 2020
    I was finally able to speak to a Netgear support rep, Rose. The delay was from my end, not theirs. She performed a factory reset remotely on my router, and I went through the steps to set up a new router. The reset was initiated from within the router web page (I don’t know exactly where on the page the reset was accessible since I was not doing it, but to be clear, it was not via the app). After the router had restarted and I finished the installation process, the SpeedTest via the app worked. Considering that the app worked for me previously and then stopped, much like what has happened to others, I’m cautiously optimistic that this is a permanent fix. But I have to say that Rose was great and I’m back in business.
  • I'm having the same problem with my Orbi RBK 753.  It was working for the first few weeks, and then stopped.  I've reset the router and modem several times, have uninstalled and reinstalled the app several times, and tried customer support.  No success.
    • Intmedhead8's avatar
      Intmedhead8
      Tutor
      When I try to use the speed test, it says " Connection Failed. If the problem persists, try rebooting your router."  I have rebooted and unplugged the router a dozen or more times.  It worked up until 3 weeks ago when my support service for Netgear expired.  I was not sure if this was a coincidence or if the speed test was a free service as long as I had the support service with Netgear.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Intmedhead8 and Fritzsche0529
    Welcome to NETGEAR Community!
    Is this on Android or iOS?
    May we please know the Android or iOS version?
    Kindly provide the Orbi App version.
    Blanca
    Community Team
      Intmedhead8
      Tutor
      Apple iPhone X.
      Orbi version 2.6.2.9
      firmware version V3.2.16.6
      • Cshartma's avatar
        Cshartma
        Guide
        I have the same problem. Speedtest in the app and on the router’s web interface have ceased to work after a firmware upgrade. I’ve vlcalled netgear support 4 times - each time on hold for 1.5 hours. None of their suggestions helped. They are not only incompetent but also Poorly managed. This is the worse customer experience I’ve had on any product.
  • RBR850
    Running a new RBR850 with Gigabit fiber from fios
    after setting up the new router and installing the latest firmware everything seemed to work. Once I rebooted the router I lost the ability to check my WiFi speeds from the app. I done a factory reset and after that I was able to check the speeds again but once I reboot the router for any reason you loose the ability to check the speeds from the app.
    also, when I was able to check the speeds from the app I would only ge5 500 MB up and down with my gigabit connection from fios.
    anyone know of this has been reported so the firmware could  be fixed.
      Fritzsche0529
      Apprentice
      Kyrunner, you're not alone.  Many of us have had this problem, SpeedTest function stopped working on the app, but the fix (factory reset) wasn't know initially.  It wasn't known why the app would work, then stop working.  You seem to be having the problem right after a router reboot...then are able to fix it with a factory reset.  Honestly, I don't want to try replicating your process because I finally got the SpeedTest working...but I will remember this if I have to reboot in the future!
      I don't know if a firmware fix is in the works, but I hope so!
  • I have RBK753. I encountered the same problem. Rebooting routers and reinstalling the app on my Android phone didn't fix it. I had the latest firmware. Netgear tech support recommended manually reinstalling the firmware, but that still didn't fix it. I did a factory reset on the router and satellites, reinstalled the apps and setup the routers and satellites again in the app. After that the speed test started working.
