Cabinew
Sep 29, 2020Guide
Orbi RBR750 Speed Test connection failed
I have the Orbi model number RBR750 (number on the bottom of device), but the box says AX4200 RBK753S. It is the WiFi 6 robust Smart Home Tri-Band Mesh WiFi 6 system from Costco. I could not find it in the model number list above.
When I try to do the speed test I get a message saying “Connection Failed if the problem persists, please try rebooting your router”
What can I do to fix this?
- capitureGuideSwitch to a more stable company. I’ve sure learned my lesson the hard way.
New eero is cheaper and service was great before I decided to give Orbi a try.- capitureGuideAbsolutely - I Loved my eero and made a HUGE mistake trying Orbi because of the fake news consumer report suggestion.
I am very disappointed with NETGEAR service and lack of software quality.
- gchin3Initiate
You're not alone in this. This appears to be an issue with the Orbi App. Netgear support is not very responsive; if you need a warranty repair, it will take weeks to get something resovled -- and they'll not honor the warranty period...without you paying for their phone support to tell you that their equipment is broken.... I would suggest that you run the speedtest.net (or fast.com) on a browser to check your network performance.
Tried so far:
Rebooted router.
Rebooted cable modem.
Deleted Orbi app; re-installed Orbi app.
Someone suggested going to settings and looking for enabling "Orbi"...however, I don't see what they're talking about....
I've sent e-mail...nothing.
Good Luck.
- capitureGuideRight - an absolute s..t show at NETGEAR!
I wanted $1400 on 3 routers and 1 modem and what a waste. Customer service is non existent.
Regarding speed test: sure you can do tests on your phone using browser, but that’s not same as the Orbi App. Because that tells you speed from modem to your connected router. Thus the speed of your internet provider.
Doing test on a browser has degradation depending on many factors on your device and distance.- CabinewGuideThanks for the feedback. Like many others. The speed test worked great for the first couple of weeks, then all of the sudden it stops working. I wonder if it has something to do with firmware upgrades. I am not that tech savvy, but hope hope they have a simple solution.
I also have this issue and would love to see a resolution.
- JImDonahueAspirant
Updating the router to the latest firmware fixed the problem for me. It's version 3.2.17.12 and you can download it from the support website.
Here's the link
https://kb.netgear.com/000062824/RBR750-RBS750-Firmware-Version-3-2-17-12
New Features and Enhancements:
- Supports the new device notification feature
- Includes some security enhancements
Security Fixes:
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
- Fixes issues with Speedtest in the Orbi app
- Fixes device access issues with the web UI
- Fixes some web UI related issues
Download Link:
RBR750 - https://www.downloads.netgear.com/files/GDC/RBK752/RBR750-V3.2.17.12_1.4.14.zip
RBS750 - https://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V3.2.17.12_1.4.14.zip
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
