Heyrip
Dec 21, 2022Guide
CBR750 now not working with Xfinity
I have CBR750 with one satellite, Xfinity is the ISP. Worked great for more than a year until Xfinity "upgraded" their system in my area (Bellevue, WA) early November, then several times I had to unplug/plugin CBR750 to get it to work. Four days ago Xfinity had an outage in my neighborhood and when system came back CBR750 no longer works. Rebooting does not help. Xfinity has been out to my house twice, and determined problem is with the CBR750 not Xfinity because Xfinity's router works (so I have temporarily rented one). Xfinity tech support says other people use the CBR750 and it works with their system. I have not tried any sort of reset or update of the CBR750 yet...it's awkward because I'm out of the country and working with renters to solve the problem. BTW, I'm not very tech-savvy.
Any suggestions on what to try would be greatly appreciated!
- FURRYe38Guru - Experienced UserIf the CBR had been working then he ISP had problems in your area then the CBR stopped working, this would fall on the ISP to correct this. The CBR would need to be hook up and would need the following posted here: What Firmware version is currently loaded? Please post a copy and paste of the modems connection status and event log page.
 https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
 https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerAre there any transmission issues reported by the ISP that they might report the CBR as being off line by chance? Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
 Be sure there are no coax cable line splitters in the between the modem and ISP service box.
 Be sure your using good quality RG6 coax cable up to the modem.
 Start with removing any amplifiers, signal attenuators, or splitters from the coax.
 From there check the line for kinks, damage, moisture in the line.
 Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
 Be sure to power OFF the modem for 1 minute then back ON.
 https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
 https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
 https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- Blanca_ONETGEAR Employee RetiredHi Heyrip, We are looking into the issue. Kindly send me a private message with the device serial number and MAC address. Regards,
 Blanca
 Community Team
- HeyripGuideJust an update if anyone is wondering...I haven't heard anything back from Netgear about this problem. No confirmation there is a problem, no comment if they have or have not found a problem, no comment it they will try (or are trying) to fix it, no comment if they will offer any credit for systems that no longer work, no comment if the CBR750 (or satellite) could somehow be used as router alone if I buy a new modem. - FURRYe38Guru - Experienced UserNG is working with the ISP on this. From what I understand there are certain CBR serial numbers that come up problematic along with issues at the ISP level. NG IS working on this. Not all CBRs are effected. The CBR can only be used has a gateway modem in gatway mode or Bridged thus modem only mode thus disabling the router and wifi portion of the CBR. How this was designed. However, you CAN use the CBR in a faux AP mode along with the RBS if you set a new IP address on the CBR that aligns with any external router you connect up and then disable the DHCP service on the CBR. Connect the CBR via one of it's LAN ports to the uptream routers LAN ports. The RBS will connect and get a IP address thru the CBR from the host router. You'll just have to cover the front LEDs as these will continually blink. I use a postit note to cover. I tried this once and it worked. Keep in touch with NG and be patient. There working on it. Should see more movement after the holidays and new year starts.
