Retired_Member's avatar
Retired_Member
Apr 12, 2022
CBR750 random disconnects
I have just the one CBR750 modem/router - no additional satellites, etc. Nearly every day at random times, I'll get disconnected and have to reboot the device.
I've tried reflashing the firmware (currently on V4.6.5.8_2.0.54), changed the 2.4 Ghz channel to 6, reset to factory settings and still getting the same results. My thinking is it's something with the line coming into the house (I have Xfinity). I don't have any splitters connected to the Coax. Any thoughts or suggestions or should I have Xfinity send a tech out to investigate?
I'm attaching my Event Log as well as the cable connection log.
TimePriorityDescription
Apr 11 2022 13:28:09Notice (6)TLV-11 - unrecognized OID
Apr 11 2022 13:28:09Critical (3)Config File Rejected due to Invalid or Unexpected TLV 11
Apr 11 2022 13:28:26Alert (2)CM Certificate Error
Apr 11 2022 13:28:35Notice (6)CM-STATUS message sent. Event Type Code: 16
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out
Apr 11 2022 13:31:43Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 11 2022 13:31:43Notice (6)TLV-11 - unrecognized OID
Apr 11 2022 13:31:43Critical (3)Config File Rejected due to Invalid or Unexpected TLV 11
Apr 11 2022 13:31:54Warning (5)RCS Partial Service
Apr 11 2022 13:32:03Notice (6)CM-STATUS message sent. Event Type Code: 23
Apr 11 2022 13:32:03Alert (2)CM Certificate Error
Apr 11 2022 13:32:08Notice (6)CM-STATUS message sent. Event Type Code: 16
Apr 11 2022 14:38:27Alert (2)CM Certificate Error
Apr 11 2022 14:47:27Notice (6)DS profile config update. DS Chan ID: 37.
Apr 11 2022 14:47:30Notice (6)CM-STATUS message sent. Event Type Code: 16
Apr 11 2022 14:48:56Notice (6)DS profile config update. DS Chan ID: 37.
Apr 11 2022 14:49:02Notice (6)CM-STATUS message sent. Event Type Code: 23
Apr 11 2022 14:50:23Notice (6)DS profile config update. DS Chan ID: 37.
Apr 11 2022 14:50:32Notice (6)CM-STATUS message sent. Event Type Code: 24
Apr 11 2022 15:04:38Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 11 2022 15:04:38Notice (6)TLV-11 - unrecognized OID
Apr 11 2022 15:04:38Critical (3)Config File Rejected due to Invalid or Unexpected TLV 11
Apr 11 2022 15:04:54Alert (2)CM Certificate Error
Apr 11 2022 15:04:57Notice (6)CM-STATUS message sent. Event Type Code: 2
Apr 11 2022 19:28:21Warning (5)Lost MDD Timeout
Apr 11 2022 19:28:27Notice (6)CM-STATUS message sent. Event Type Code: 23
Apr 12 2022 06:40:07Notice (6)DS profile config update. DS Chan ID: 37.
Apr 12 2022 06:40:12Notice (6)CM-STATUS message sent. Event Type Code: 24
Apr 12 2022 06:41:39Notice (6)DS profile config update. DS Chan ID: 37.
Apr 12 2022 06:41:46Notice (6)CM-STATUS message sent. Event Type Code: 2
Apr 12 2022 11:28:57Warning (5)Lost MDD Timeout
Apr 12 2022 11:28:58Notice (6)CM-STATUS message sent. Event Type Code: 24
Time Not EstablishedWarning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Apr 12 2022 12:05:56Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 12 2022 12:05:56Notice (6)TLV-11 - unrecognized OID
Apr 12 2022 12:05:56Critical (3)Config File Rejected due to Invalid or Unexpected TLV 11
Apr 12 2022 12:06:15Alert (2)CM Certificate Error
Apr 12 2022 12:06:20Notice (6)CM-STATUS message sent. Event Type Code: 5
  • FURRYe38's avatar
    What FW is loaded on the CBR?
    I see some Config File Rejected due to Invalid or Unexpected TLV 11 entries that the ISP needs to look in to.
    Please post a copy and paste of the modems connection status page.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
    https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
    • Retired_Member's avatar
      Retired_Member
      Firmware is V4.6.5.8_2.0.54
      Startup Procedure
      ProcedureStatusComment
      Acquire Downstream Channel507000000 HzLocked
      Connectivity StateOkOperational
      Boot StateOkOperational
      SecurityEnabledBPI+
      IP Provisioning ModeHonor MDDhonorMdd(4)
      Downstream Bonded Channels
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectable
      1LockedQAM 2562489000000 Hz-11.5 dBmV36.6 dB30
      2LockedQAM 2563495000000 Hz-11.7 dBmV36.3 dB20
      3LockedQAM 2564501000000 Hz-11.4 dBmV36.3 dB00
      4LockedQAM 2565507000000 Hz-11.7 dBmV36.3 dB20
      5LockedQAM 2566513000000 Hz-11.5 dBmV35.5 dB00
      6LockedQAM 2567519000000 Hz-11.9 dBmV36.3 dB00
      7LockedQAM 2568525000000 Hz-12.2 dBmV35.5 dB00
      8LockedQAM 2569531000000 Hz-12.2 dBmV35.0 dB00
      9LockedQAM 25610537000000 Hz-12.5 dBmV34.9 dB00
      10LockedQAM 25611543000000 Hz-12.5 dBmV35.5 dB00
      11LockedQAM 25612549000000 Hz-13.2 dBmV34.7 dB00
      12LockedQAM 25613555000000 Hz-13.0 dBmV35.5 dB00
      13LockedQAM 25614561000000 Hz-13.3 dBmV35.0 dB00
      14LockedQAM 25615567000000 Hz-12.7 dBmV35.7 dB00
      15LockedQAM 25616573000000 Hz-13.3 dBmV34.0 dB00
      16LockedQAM 25617579000000 Hz-13.5 dBmV34.3 dB00
      17LockedQAM 25618585000000 Hz-13.5 dBmV35.0 dB00
      18LockedQAM 25619591000000 Hz-13.7 dBmV33.8 dB00
      19LockedQAM 25620597000000 Hz-13.7 dBmV34.3 dB00
      20LockedQAM 25621603000000 Hz-14.3 dBmV34.9 dB70
      21LockedQAM 25622609000000 Hz-14.3 dBmV34.4 dB00
      22LockedQAM 25623615000000 Hz-14.8 dBmV34.4 dB110
      23LockedQAM 25624621000000 Hz-14.0 dBmV34.3 dB70
      24LockedQAM 25625627000000 Hz-14.0 dBmV33.9 dB20
      25LockedQAM 25626633000000 Hz-14.0 dBmV34.4 dB10
      26LockedQAM 25627639000000 Hz-14.4 dBmV34.3 dB00
      27LockedQAM 25628645000000 Hz-15.7 dBmV33.4 dB00
      28LockedQAM 25629651000000 Hz-15.8 dBmV33.3 dB00
      29LockedQAM 25630657000000 Hz-16.0 dBmV33.0 dB00
      30LockedQAM 25631663000000 Hz-16.4 dBmV32.9 dB20
      31LockedQAM 25632669000000 Hz-16.0 dBmV32.9 dB1144136263
      32Not LockedN/AN/A0 Hz0.0 dBmV0.0 dB00
      Upstream Bonded Channels
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA45120 Ksym/sec16400000 Hz45.0 dBmV
      2LockedATDMA35120 Ksym/sec22800000 Hz46.0 dBmV
      3LockedATDMA25120 Ksym/sec29200000 Hz46.5 dBmV
      4LockedATDMA15120 Ksym/sec35600000 Hz46.3 dBmV
      5LockedATDMA52560 Ksym/sec40400000 Hz47.0 dBmV
      6Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
      7Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
      8Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
      Downstream OFDM Channels
      ChannelLock StatusModulation/Profile IDChannel IDFrequencyPowerSNR/MERActive Subcarrier
      Number Range
      Unerrored
      Codewords
      Correctable
      Codewords
      Uncorrectable
      Codewords
      1Locked337690000000 Hz-15.5 dBmV32.5 dB1108~2987000
      2Not Locked000 Hz0.0 dBmV0.0 dB0~4095000
      Upstream OFDMA Channels
      1Not Locked000 Hz0.0 dBmV
  • FURRYe38's avatar
    For one the power levels are too low:
    Something that the ISP needs to check on. Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
      Retired_Member
      Thanks for the replies. Last night I checked behind the wall plate where the line is coming into the house. There was an old splitter and a kinked coax cable, which goes directly to the modem. I replaced the splitter and coax and I'm seeing a huge improvement in the power levels. Still not ideal, but much closer to normal ranges. So far no disconnects and the event log is clean, but I'll give it another few days to see how things look.
      Startup Procedure
      SecurityEnabledBPI+
      1LockedQAM 2562489000000 Hz-5.5 dBmV38.6 dB50
      2LockedQAM 2563495000000 Hz-6.0 dBmV38.6 dB00
      3LockedQAM 2564501000000 Hz-6.0 dBmV38.9 dB00
      4LockedQAM 2565507000000 Hz-6.2 dBmV38.6 dB00
      5LockedQAM 2566513000000 Hz-5.9 dBmV38.9 dB00
      6LockedQAM 2567519000000 Hz-6.2 dBmV38.9 dB00
      7LockedQAM 2568525000000 Hz-6.5 dBmV38.9 dB00
      8LockedQAM 2569531000000 Hz-6.9 dBmV38.6 dB00
      9LockedQAM 25610537000000 Hz-7.0 dBmV38.6 dB00
      10LockedQAM 25611543000000 Hz-6.7 dBmV38.6 dB00
      11LockedQAM 25612549000000 Hz-7.4 dBmV38.6 dB00
      12LockedQAM 25613555000000 Hz-7.2 dBmV38.6 dB00
      13LockedQAM 25614561000000 Hz-7.5 dBmV38.6 dB00
      14LockedQAM 25615567000000 Hz-7.2 dBmV38.6 dB00
      15LockedQAM 25616573000000 Hz-7.5 dBmV38.9 dB00
      16LockedQAM 25617579000000 Hz-7.7 dBmV37.6 dB00
      17LockedQAM 25618585000000 Hz-7.5 dBmV38.6 dB00
      18LockedQAM 25619591000000 Hz-8.0 dBmV38.2 dB00
      19LockedQAM 25620597000000 Hz-7.7 dBmV37.6 dB10
      20LockedQAM 25621603000000 Hz-8.4 dBmV38.6 dB00
      21LockedQAM 25622609000000 Hz-8.4 dBmV37.3 dB00
      22LockedQAM 25623615000000 Hz-8.7 dBmV37.6 dB00
      23LockedQAM 25624621000000 Hz-8.5 dBmV37.6 dB30
      24LockedQAM 25625627000000 Hz-8.4 dBmV37.6 dB1936
      25LockedQAM 25626633000000 Hz-8.5 dBmV37.6 dB841
      26LockedQAM 25627639000000 Hz-8.7 dBmV37.6 dB843
      27LockedQAM 25628645000000 Hz-9.5 dBmV37.6 dB645
      28LockedQAM 25629651000000 Hz-9.9 dBmV37.3 dB645
      29LockedQAM 25630657000000 Hz-10.4 dBmV37.3 dB643
      30LockedQAM 25631663000000 Hz-10.7 dBmV36.6 dB1041
      31LockedQAM 25632669000000 Hz-10.2 dBmV36.6 dB1936
      1LockedATDMA45120 Ksym/sec16400000 Hz40.5 dBmV
      2LockedATDMA35120 Ksym/sec22800000 Hz40.8 dBmV
      3LockedATDMA25120 Ksym/sec29200000 Hz41.0 dBmV
      4LockedATDMA15120 Ksym/sec35600000 Hz41.8 dBmV
      5LockedATDMA52560 Ksym/sec40400000 Hz42.0 dBmV
      Number Range
      Unerrored
      Codewords
      Correctable
      Codewords
      Uncorrectable
      Codewords
      1Locked337690000000 Hz-9.5 dBmV37.7 dB1108~2987000
      • FURRYe38's avatar
        Ok. Levels are a bit to low now. Might ask the ISP for tech to visit on site if you seem to continue to have problems. If we can get the power levels to a happy mid spot would be preferred.
