mirage_man
Sep 29, 2020Guide
Chamberlain MYQ Orbi752 won't connect
Recently upgraded to a new mesh Orbi 752 system and all is working well except I can't get it to connect with my Chamberlin garage door opener MYQ. I know this is an issue resulting from the fact that the myq is only 2g and the orbi is both 2g and 5g. I've tried turning off the 5g and it still won't work.
I spoke to tech support and they said there's two options... Reduce the 5g signal or add a second router specifically for the myq. I have an older Asus router and I tried following a tutorial to add it to the orbi and I couldn't get it to work. Ended up having to factory reset the orbi.
Anyone have a suggestion here? Tech support said they would help me set it up if it was another Netgear brand router. I don't have a problem getting a cheap one for this purpose if I have to but not sure what would be the best way to go.
- Wouldn't you know it but Chamberlain support had a fix!
Apparently the issue was using the Android app to try to connect. They showed me a work-around using a web interface to authenticate the network.
Here's what I did..
#1) Go through steps to update wifi settings via control panel on opener itself. (push and hold rectangular button until led button lights turn off on unit. Then push yellow round button 3 times. Rectangular button will blink blue.)
#2) Go to wifi settings in phone and myq opener should be visible. Select it. Let it connect.
#3) Open a browser on phone. Type in "setup.myqdevice.com" and enter. It will open a web interface for setting up the wifi. Follow prompts and it should work. It did for me and I was even able to leave AX mode enabled as well as go back to regular wpa2.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://https://https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerHad the garage device worked before you got the Orbi AX with a different router? Are you using the same SSID name and PW on the Orbi AX as on the prior router?
Try disabling AX mode on both radios.
Try setting CTS values to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
IF you reduce the power output of the 5ghz radio, you need to disable the wifi radio on your setup mobile device for the garage device. Walk out farther from the RBR or RBS, then turn ON the mobile device and then it should connect to the 2.4Ghz radio. I would turn OFF the RBS for this process while you attempt to get the garage device setup so your only dealing with 1 wifi signal.
mirage_man wrote:
Recently upgraded to a new mesh Orbi 752 system and all is working well except I can't get it to connect with my Chamberlin garage door opener MYQ. I know this is an issue resulting from the fact that the myq is only 2g and the orbi is both 2g and 5g. I've tried turning off the 5g and it still won't work.I have a Liftmaster MyQ/wi-fi enabled garage opener motor connected to my Orbi RBR850. I don't recall a problem connecting to it because the procedure involves connecting to the unit's own 2.4Ghz wifi and then picking the network the opener tells you it wants to connect to. Since the opener only understands 2.4Ghz, it lists only 2.4Ghz networks. I don't think this has to do with 5Ghz sharing the 2.4Ghz SSID (this only causes problems when a phone app tries to use the phone's wireless connection, which may be 5Ghz or 2.4Ghz, to decide what to connect to). Your problems with your old Asus router seem to also indicate a non-5Ghz issue.
For best 2.4Ghz compatbility in Orbi AX systems, in http://orbilogin.com/ go to Advanced... Advanced... Advanced Wireless Settings and set CTS/RTS to 2347 for both bands. If that still doesn't work, try disabling AX mode (uncheck the box) for 2.4Ghz.
- I'll give that a shot next. Turning of AX mode did not work.
And to a address a previous comment.. My old asus router worked fine. It wasn't until upgrading to the orbi that it became an issue.- FURRYe38Guru - Experienced User
What browser are you using? There should be some input value boxes to the right side of that screen. 64 will be seeing in two boxes. Change this to 2347.
Try a different browser?
Try disabling AX mode if you have tried this as well.
- js16301Initiate
I have an RBR850 and was having a hard time also, I turned off the AX on the 2.4 GHZ and reset my WiFi using the instructions on page 32 of the owners manual. After that I didn't have any issues and was able to connect. Hopefully this works for you
Thank for letting us know.
Enjoy.
js16301 wrote:I have an RBR850 and was having a hard time also, I turned off the AX on the 2.4 GHZ and reset my WiFi using the instructions on page 32 of the owners manual. After that I didn't have any issues and was able to connect. Hopefully this works for you
Any progress on this?
Anyone have a suggestion here? Tech support said they would help me set it up if it was another Netgear brand router. I don't have a problem getting a cheap one for this purpose if I have to but not sure what would be the best way to go.- Not yet. Haven't had a chance to work on it until now. I'll update shortly if I can get it working.
