dbnorton
May 08, 2022Tutor
I really hope they are able to fix this soon...
I really hope they are able to fix this soon. I really don't want to have to completely factory reset my router!! I have a lot of home automation stuff that would all have to be touched. Most of those devices had static IP's setup. This is like a perfect storm for me as I lost a hard drive on one of my PC's that had my backup on it and now its gone! I even nmap'd the router IP and only 2 ports are showing open ports 53 and 5000. This really sucks!
Be sure you have a backup configuration to file for safe keeping. A factory reset maybe needed.
- ecwGuide
My Orbi login bombed out today (05/08/2022) as well. I have an Android w/o zero updates recently. I can't log into it via the browser on my desktop nor the app on my phone.
Did NetGear push out an update today or recently that might have caused this? I can't log in to check to see if it was updated obviously.
E
Just a suggestion here, maybe netgear could backup the devices it is updating prior to pushing out updates? If a hard reset is part of the recommended actions post update, netgear should be allowing the schedule of said updates. Alternatively, I am sure most users would not mind providing a google drive or other cloud storage area for storing a file that could save them 3 hours of reconfig.
- ecwGuideI haven't performed the factory reset yet as I can't do that in the middle of the work day. Once I 30/30/30 reset it later, I will post the results.
I do have a family member that has the same model of Orbi but is running 4.6.5.14. that previous version is stable. The hot mess started when 4.6.8.2 was forced/auto updates to my router.
- mcdanTutor
At around my Orbi went offline May-07-22 ~@9:14 UTC. As a lot of folks in this thread I haven't been able to reach the management UI at all.
nmap -O 192.168.1.1 Starting Nmap 7.92 ( https://nmap.org ) at 2022-05-07 19:48 EDT Nmap scan report for 192.168.1.1 Host is up (0.0063s latency). Not shown: 998 closed tcp ports (reset) PORT STATE SERVICE 53/tcp open domain 5000/tcp open upnp MAC Address: 08:36:C9:78:11:6F (Netgear) Device type: WAP Running: Linux 3.X|4.X OS CPE: cpe:/o:linux:linux_kernel:3.18 cpe:/o:linux:linux_kernel:4.1 OS details: OpenWrt Chaos Calmer 15.05 (Linux 3.18) or Designated Driver (Linux 4.1 or 4.4) Network Distance: 1 hop
It's clear the HTTP port isn't even open. So there is no way to manage the router. I cannot mange the router at all, they have effectively bricked the device.
All my devices connect to the internet fine, even more advanced things like the VPN are working. Forcing down an update that breaks such an obvious part of the system is really huge mistake.
There are a lot of people having this exact problem: https://www.reddit.com/r/orbi/comments/ukmdhw/orbi_providing_wifi_and_connecting_to_internet/
Have people tried a factory reset and setup from scratch using a wired PC and web browser pointed to HTTP and 192.168.1.1?
- mcdanTutor
I have not tried personally. If I factory reset won't they push the same firmware back to me again at some point and won't I be right back here again?
If they can force a firmware update to fix this that would be much easier than asking everyone to set everything back up again from factory default. Given that they forced a firmware update that broke this for at least some subset of users. How many people just haven't looked at their Management UI lately, probably loads.
I looked at my 7 series this morning. I set it back to v.13 last nite. Re-updated to v2 this morning at 1AM. I was able to get in to the RBRs web page fine using HTTP. Also Orbi app is working too. Thought I have Private Address and IP Tracking disabled on my phone. Orbi is in AP mode as well. I'll be trying Router mode later today.
- defihodlInitiate
Agreed. I cannot do a full reset with a house full of people working from home. And, I do not want to reconfigure my attached devices. I will just wait for another update. I just hope I will not need to connect to the router in the meantime.
Make contact with NG support and ask for help on this.
- sprizleAspirant
Agree. Same issue persists as of May 24. Many devices with static IPs. If I have to factory reset, I'll use this time to upgrade to another brand of router. Very frustrating issue.
