bestsongever99's avatar
Aug 05, 2021
Missing confirm button when manually updating firmware.
When trying to manually update my firmware to downgrade? Since "updating" to new version V4.6.3.7_2.0.49 I have been having issues connecting to Wi-Fi, dropping connections when streaming Plex or any type of service at least twice every 10 minutes sometimes more. But when I tried to manually update my firmware I setup the RBS750 just fine but then after I try to do the router and apparently they remove the yes/confirm button so I'm stuck with this update that has been horrible right after I downloaded it. Sometimes certain devices can connect to the Wi-Fi but it can't connect to the internet even though it's available but if I open a guest Network they can log in just fine. Does anybody have any ideas for me please? Also I have the RBR75 Orbit AX4200 Tri-band wiFi Router but of course it's missing from their model list.
  • michaelkenward's avatar
    michaelkenward
    You might get more help, and find earlier questions and answers specific to your RBR50 device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
  • FURRYe38's avatar
    Downgrading from v4 to v3 is not supported.
    Try a factory reset on the RBR and RBS and setup from scratch. If your problems continue, please open a support ticket with NG.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi bestsongever99
    The downgrade from FW v4.6.3.7 back to 3.2.18.1 is not supported. Therefore you will notice that there isn't an option to click "Yes".
    Please check your inbox. I have sent you a message requesting for more information.
    Blanca
    Community Team
