g60919
May 24, 2026Aspirant
Orbi RBK760 firmware issues
i have a Orbi 760 with 2 satellites , recently i updated the router to newest firmware V6.3.8.11_1.4.83 , now all control functions not working , sleep time , pause internet or security options all n...
May 26, 2026Guru - Experienced User
You can use the RBS self service web page to either downgrade or upgrade the FW directly to there web page. Then once that has taken, upgrade or downgrade the RBR.
Orbi Satellite (RBS) Self-Service Web Page Access | NETGEAR Communities
Yes, please do a factory reset and setup from scratch to make sure all is working after either up or downgrade.
Can follow this guide for that:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
