skalman14's avatar
skalman14
orbi RBR 860
I have this router, and it keeps droping all the wifi items on the main wifi, even on the iot network. called netgear they do not know what to do.
also the router has the dhcp renewing the ip address every 30 min which i feel is the concern.
setup
froniter
500/500 gateway
to router nothing crazy nice and easy
anyone have a clue to help
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • skalman14's avatar
      skalman14
      so i have a gateway  i am not using double nat in any way or foam.
      it hs the lastest software that was just out per netgear.
      do not have a satelight at all.
      and it is 2500 sqft
      • FURRYe38's avatar
        So if you have a gateway modem then you would be using double NAT if the modem is not put into bridge mode or your using the gateways DMZ for the RBR.
        What is the actual FW version being used on the RBR?
        Does this happen with both wireless and wired devices?
        What channel configurations are currently set on the router?
        What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    setup
    froniter
    500/500 gateway
    Long shot, but easy enough to try.  I had as similar issue that involved IPv6 re-upping often and causing disconnects.  Turning off IPv6 helped.  You might try that temporarily to see if it makes a difference.
