wofie2a's avatar
wofie2a
Tutor
Jun 14, 2020
ORBI RBR50 Wired Backhaul not working
I have been struggling for 2 days trying to get the wired backhaul working on my Orbi 853 setup with one Wired Backhaul and 1 Wireless Backhaul satellite.  I read a lot of posts that said you needed to wait 5 minutes for the satellite to register to no avail.  I finally solved the problem and I wanted to share it to help others.
There is a special sequence of events that need to occur to "register" the satellite as wired.  I had setup my Orbi per instructions, wireless connections for all and latest firmware.  I then moved my satellites to their final location and connected the satellite via the wired network connection to the router. The new locations of my satellites were not in wireless range of the router ( basement with thick concrete walls ).
In order for the wired connection to be "registered" it MUST be in wifi range of the router when connecting the ethernet wire.  You can then move it to its final placement in your home / business via ethernet wire.  If you try to connect the device by a wired connection without first connecting it ( with ethernet ) while it is in range of wireless, you will find that the satellite creates its own "open" wireless network of the same name as your wifi ( basically a stand alone access point ).
Once I brought the sattelite into wireless range and connected it to the wired ethernet backhaul, I could then transport it to a place where it was not in wireless range of the router and it registered almost immediately upon booting.
This solved the mystery.  Hope this helps everyone.
Best
Wolfie
  • CrimpOn's avatar
    CrimpOn
    Alas, you are more likely to get an informed response if you post in the community forum devoted to the AX product line.
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Most of the people who participate in this forum have the older WiFi5 product.
    I seem to recall hearing that there were "issues" with regard to the AX product and ethernet backhaul.  But, not having one I have not tried to follow that topic.
    Good Luck
  • FURRYe38's avatar
    What FW version are you using?
    Best
    Wolfie
    • Dd852's avatar
      Dd852
      Luminary
      Very interesting - but now I'm confused. I didn't set up that way (went direct to the final location, out of range of the router, and plugged in the wire) yet the interface shows it as a wired connection. While I should just relax and be happy, I do have glitches still ( one device in particular that doesn't roam smoothly from area to area) that suggest that the wired backhaul isn't behaving 100%. Before you did this procedure, how did the satellite appear on the interface?
  • schumaku's avatar
    schumaku
    Wolfie, Very useful and correct explanation, this is the working way to configure an Orbi system for a wired backhaul.  Just for curiosity: You talk in the post of the RBK853 - but the subject is RBR50 - and I assume this is not a mixed system?
    • wofie2a's avatar
      wofie2a
      Tutor
      Yes it is not a mixed system. Also there were a number of people with this problem that suggested if a switch was involved in the connection between the satellite and router. Both work fine if this procedure is followed.
      • wofie2a's avatar
        wofie2a
        Tutor
        Also the 853 when you view it in the app says 850.
  • Hi
    I have read plenty about how to set up wired backhauls, but what I cannot see is if it is possible to set one up from one satellite (number 3) to another (number 2) where number 2 is connected wirelessly to the router? Is it possible to mix wired and wireless without having to go wired all the way back to the router?
    thanks for your help!
    • FURRYe38's avatar
      Anything is possible. You can try it out and see and let us know? I haven't tried that configuration.
      Hambledom wrote:
      Hi
