rwjacks2's avatar
Apr 16, 2025
Orbi RBR750 satellites not connecting to RBR750 router. Appear to be constantly rebooting??
My Orbi mesh network has been working great for 3 years.  Recently none of my 3 satellites are connecting to the router.  They appear to be rebooting.  I get flashing white LED then solid blue for minute or two then back to flashing white.
Things I have tried:
* I reverted back to the previous FW version on router with no change.  Given satellites are not connecting I assume they are still on the latest version.
* I reinstalled latest FW on router with no change in behavior.
* I did a factory reset on satellites and router and end up with same behavior.
Wondering if I could back off to previous FW version on satellites that would get me back to a working state?
If you have any suggestions of other things to try, let me know.
Thanks,
-RIley
  • FURRYe38's avatar
    What Firmware version is currently loaded? RBR and RBS should be on save FW version always.
    How was FW updated on the system?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    What channel configurations are currently set on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
    Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • rwjacks2's avatar
      rwjacks2
      Tutor
      Router and all satellites are on FW version: V7.2.7.15_5.1.16
      Initially FW was installed automatically.  I manually installed previous version on router and then manually updated to current version (V7.2.7.15_5.1.16)
      Modem is a Arris SURFboard 6910.
      Home sq feet is 3300.  No changes to any hardware or location of router or 3 satellites in past 2 years.  No changes in wifi settings.  Satellites are about 20-30 feet apart.  All had blue LED connections to mesh.  All 3 satellites are exhibiting the exact same behavior.
      Right now I have moved one satellite within 20 feet of router and turned other two off.  Have tried the power off sequence of network devices as suggested with no change in behvavior.
      When I power up the sattelite I see it show up in Netgear web app in Attached Devices for one second and then is show it as Disconnected.  IP address assigned is 192.168.1.250
      Changes to 2.4Ghz and 5Ghz channel numbers had no impact.
  • plemans's avatar
    do the satellites work if you hardwire them in?
    • rwjacks2's avatar
      rwjacks2
      Tutor
      Yes, hardwired worked.  Can go to assigned IP address and see status.  Shows up at RBS 350 and FW version is:  V4.6.3.16
      It is listed in Netgear web app Attached Devices in Connected Devices.  Does not show up in Connected Satellites.
