Skycutie's avatar
Skycutie
Orbi satellite rbs850 wrong serial number
The WiFi keeps dropping connection. Upon further inspection, I noticed the serial numbers from the app & actual satellite are wrong.
How do I fix this? And will this actually make the satellite work?
This has been a fiasco trying to improve my WiFi range with Orbi.
Thank you in advance for your prompt response.
    Any new firmware update recently?
    Roboot the Orbi and see if it corrects it. Instead of the app, what does it show if you go to orbilogin.com?
    • CrimpOn's avatar
      CrimpOn
      Where does the Orbi web interface show the serial numbers for the router and satellite(s)?
      I so seldom use the "app" that I had never noticed that it displays the device serial number.  Have been through much of the web interface and cannot find it.
      • Mstrbig's avatar
        Mstrbig
        Master
        Don't think it's available in the Web interface.
        In the app Load the app, click the big router, click on router or one of the satellites, click details.
    • Skycutie's avatar
      Skycutie
      Thanks!
      Gave us a hard reset...
      it’s still in/out. When I test the WiFi speed Orbi has crazy high numbers vs. Speedtest app (which I’m finding much more accurate).
      The website reads the same serial numbers as the app for the satellite.
      • FURRYe38's avatar
        What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
        Be sure to post about Orbi AX questions or information over in the Orbi AX forum:
        https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
        Skycutie wrote:
        Thanks!
