dglsmcd_USMC
Apr 29, 2020Luminary
RBK852 Firmware Update V3.2.11.2_1.2.13
Not showing up on the NG server yet. Had to manually install-RBS850 FIRST-then RBR850 followed by a hard reset and fresh install-do not use previous config files.
Here are the links:
RBR850
http://www.downloads.netgear.com/files/GDC/RBK852/RBR850-V3.2.11.2_1.2.13.zip
RBS850
http://www.downloads.netgear.com/files/GDC/RBK852/RBS850-V3.2.11.2_1.2.13.zip
Wondering if this includes an AP mode fix...Hmm.
Thanks for posting.
Bug Fixes:
- Includes bug fixes for three Orbi Satellites that are connected to the Orbi network
https://kb.netgear.com/000061862/RBR850-RBS850-Firmware-Version-3-2-11-2
Off to testing we go. :smileywink:
- KMDonlonVirtuosoIs this beta or official firmware?
Anything posted on NGs support download site is not beta.
- DoctorALuminary
What were the problems to begin with using 3 Orbi Satellites that are connected to the Orbi router?
I am successfully using 3 wired satellites for many months now, 1 RBS 850 and 2 RBS50.
Router is in Router mode.
Well sad to say that v11.2 doesn't fix RBS status in the RBRs UI when in AP Mode with a LAN switch in between the RBR and RBS. Still broke here. :smileysad: Take the LAN switch out and RBS status appears correctly in the RBRs web page and Orbi app with RBS directly connected ethernet to the back of the RBR. :smileywink:
Happy to report that in router mode on the RBR with a LAN switch in the middle and the RBS ethernet connected to the switch status reports correctly on the RBRs web page and in the Orbi app. :smileyhappy:
Also default values for CTS and RTS are at 64 in this version again. So for those of you seeing problems after you update, besure to set 2346 or 7.
- KMDonlonVirtuosoJust upgraded and my CTS/RTS values remained at 2347 as I previously had them set up. Weird yours changed back.
