simdim
Oct 13, 2022Tutor
RBR750/RBS750 AP mode grayed out
Hi all,
I need to put real firewall in front of my Orbi RBR750 (V4.6.9.11_2.3.5), but AP MODE/Router is grayed out
Am I doing something wrong?
Also do I need RBSes to be physically plugged into RBR LAN ports or I can put them on separate VLAN to appear behind RBR?
What browser are you using? I use MS Edge.
Be sure to clear out all browser caches.
If you select that it doesn't display any AP mode configuration UI at all?
Might need to factory reset and setup from scratch...
Perhaps you could explain the reasons behind wanting to put the satellites on a VLAN. As long as the satellites appear to the router as being connected to the router LAN port(s), the router does not care how data packets flow between the devices.
For example, there could be a managed switch connected to one of the router LAN ports with the switch port being on LAN x. Other managed switches could be connected to that switch and (eventually) the satellites could be connected to ports that are also on LAN x. That was actually the solution devised for how to share WAN and LAN traffic over a single Ethernet cable:
https://community.netgear.com/t5/Orbi/Disabling-automatic-subnet-reconfig/m-p/2031354#M110164
So, what's the goal?
- simdimTutor
It is my understanding that in AP mode RBR has to be connected via WAN port and satellites need to be delivered to LAN ports or RBR in order to maintain "mesh" functionality. I just wanted to carve out "satellite" segment on the switch for RBSes in order not create loops.
If only RBR had more flexibility in FW rules ...
"Loops" is a topic that comes up on the forum, but usually in the context of satellites having simultaneous WiFi and Ethernet connection to the router. Not certain that creating a VLAN on the switch side would affect this.
My guess is that you seek for the firewall to control outgoing connections? The Firewall already rejects all incoming connections except for those specifically allowed by the user. (Port Forwarding). Yes, for that purpose an external firewall is the only option.
- simdimTutor
Mystery of "grayed out" is solved:
If WAN aggregation is set to enabled (WAN port and 1st LAN port are LACP bound) you can not switch to AP mode.
After disabling WAN aggregation - it is allowed.
But here comes a huge BUT with AP mode and wired backhaul ...
Consider the setup:
This works
Internet router -> switch -> WAN port RBR | LAN Port RBR -> LAN port RBS
This is what I need and it does not:
Internet router -> switch VLAN 1 (802.1Q or Port Based)-> WAN port RBR | LAN Port RBR- > switch VLAN 1 (802.1Q or Port Based -> LAN port RBS
VLAN based setup creates a loop with RBR
I had to resort to 2 additional Physical switches and additional cable run to make that setup work .
All my cat6 from RBS are in the basement, in order to get wiring to the first floor where I want RBR I need to run 4 wires between the floors if no additional switches are used, instead of riding a VLAN trunk between basement and first floor switches - this is not good thinking from Netgear ... may be it is time to look somewhere else ... the Orbi product line is just too consumer oriented and it is just too simplistic.
Well its considered a home class product. Can do some small business stuff I presume. You might look at Orbi Pro.
Glad you got it figured out. Thanks for letting us know. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
