cjf191's avatar
cjf191
RBR850 loses management access after power outage
After a power outage my RBR850 loses the management access. The Internet still works - all devices are connected and working and I can remotely access household published services from the Internet.
I can’t access the router console via the app or a web browser. It has its IP address and can be pinged but it isn’t publishing a http port 80. Last time this happened I had to factory reset and restore the backed up config. Has anyone else seen this behaviour?
The router is connected to an NBN modem in bridge mode, and has one satellite which also works fine after the power outage.
  • plemans's avatar
    Whenever I read that there's a gateway in bridge mode behind another router and there's issues accessing the GUI, it makes me question the gateway. Try powering off the gateway, reboot the netgear, and then see if you can access it when connected to it. I understand you won't have internet but its to check if it accessible without the gateway connected "in bridge mode"
    • cjf191's avatar
      cjf191
      Thanks. This makes no difference. Given the router isn’t publishing a http port I can’t access it through the web browser.
      • FURRYe38's avatar
        What FW is loaded on the RBR?
        Is IPv6 enabled on the RBR?
        Using ISP DNS addresses or custom DNS addresses?
        What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
        Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
  • FURRYe38's avatar
