SG2010
Feb 08, 2023Aspirant
RBS850 Missing Connected Device
I just upgraded my RBR50 to RBR850. The setup was easy but in connected devices, I couldn't see any of the PC that's connected the my Satellite (RBS850). It only happened to wired PCs only. The PCs can get an IP but just can't be displayed in the "Connected Devices"
When I disconnect the Wire and use WIFI to connect to router it showed up in "Connected Devices".
Any one experienced this issue? (I didn't see this with my RBR50 and the network setup is the same.)
Sometimes it is useful to contrast the Orbi 'app' "Connected Devices" with the Orbi web management interface "Attached Devices".
See page 103 of the User Manual: https://www.netgear.com/support/product/rbr850.aspx#docs
Could you see if they match? (or do not match)
- SG2010Aspirant
I did try both with app and web, the number of devices in web matched the number of devices in app.
i.e. I still don't see the 2 "wired" PC in connected Device.
The reason why I need to see them is because I want to give them "reserve" IP so that I can port forward easily.What I don't understand is that if both PC got an IP from the router, how come the router don't see the PC.
And seems that it only happened to wired PC as if I use WIFI on the same PC and disable the NIC, I can see the PC in connected device in both place.
If these are Windows PCs, open a command window and type the command
ipconfig
This will display information about each of the network adapters, including the IPv4 address.needed for the LAN Setup table.
ipconfig /all will display much more information, including the hardware MAC address which is also required for the LAN Setup table.
Knowing the IP address, there is no device in the Attached Devices display with that IP address?
Any progress on this?
Any one experienced this issue? (I didn't see this with my RBR50 and the network setup is the same.)- SG2010Aspirant
I submitted a ticket and the support team seems to claim that it might be bug in the current firmware. Since the computer is getting connections and I was able to even do port-forwarding and reserve IP. It's not blocking me at all. I was told that I will be notified once this problem is fixed.
