Guru0006's avatar
Guru0006
Satellite poor speed RB960
Have talked to tech support for 2 weeks. I initially was getting 560 MBPS speed wirelessly at router and still am consistently. The satellite which is just 15 feet away in my bedroom I was getting 460 MBPS which should be 490-520 according to Nethear support. After all tweaks they made me do I have 310-330 MBPS top speed wirelessly. I tried moving satellite all over the room no change. They updated firmware and I rebooted system countless times. Any ideas? I have changed channels as well and am using wifi6e. Have both an old Samsung S21 Ultra and S22+ both 6e capable. So frustrated and may return system today if I can not solve issue
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Be aware that some WiFi devices may top out at lower speeds as they are limited by there MIMO configuration. 2x2 usually cap at 300-500Mpbs on 5Ghz AC. AX may see around 700Mpbs. 6Ghz will be the same. 4x4 MIMO devices can see over 900Mpbs on 5Ghz AC and AX.
    Also distances from either RBR or RBS will impact speeds as well. Nearest will be good speeds, farther, speeds will drop. Nature of the wifi beast.
    5 and 6Ghz signals are effected by building materials as well.
    • Guru0006's avatar
      Guru0006
      It is running latest firmware.  V6.0.3.85_3.1.15
      I am using a Motorola router MB8600 Docsis 3.1 using Cox Cable 500 MbPS service.  It is clocking consistently at 560-570 MbPS.
      Home is 1400 sq feet 2 floors but just getting the satellite on second floor where the router is is what I am focusing on.  Router is placed centrally located n home and I have tried satellite in various locations even moving it to same room as router and still to no avail.  At MOST it is 25 ft away but I have placed it closer and doesn't seem to make major changes to signal.  Now when I first tested the satellite in my bedroom I was able to get it up to 460 MbPS but now it is not going over 330 at most even with the pieces placed in same locations.  It's very odd.  Almost like it's throttling speed.  Only changes to setup was the DNS numbers to the modem.  Otherwise all pretty simple and basic.
      • Guru0006's avatar
        Guru0006
        Orbi support had me hard reset the satelite and reboot router and is now getting 350 speed.  Still FAR below what it was.
