Phyber
Dec 22, 2025Apprentice
What are the recommended Channels and Channel widths for an RBR750 system?
Thinking about tweaking my system but it's been a long time since I've done that so what are the recommendations for 2.4GHz and 5GHz channels and channel widths. Simple home system, nothing elaborate.
- PhyberApprentice
Thanks gentlemen. I do not have a WiFi analyzer on my iPhone and I'm not sure how to use one if I did. For 2.4GHz I have it set to Auto. For 5GHz, I believe it's set to 48, which is 36 + 40 + 44 +48(P).
I use the Guest Network (re-named to something else with its own pw) for my IoT devices. Most of which are 2.4GHz only but some use the 5GHz band. I do not use the named IoT network at all.
Both of these are reasonable.
Are you seeing any wifi performance issues?
- PhyberApprentice
Not really. Just looking to see if I can squeeze a little more performance out of my system. I just updated to the latest firmware for the 750 yesterday. That went well and appears to be stable, so I like to check with those who know than I do about networking to see if there is a better config setup.
Find out whos near by your home with other wifi signals. Find the lowest used channel on 2.4Ghz and 5Ghz. Primary channels to use on 2.4Ghz is 1, 6 or 11 and 5Ghz is 36 thru 48.
I use manual 1 and 40 for my system here keeping away from other used channels.
You can change 20/40Mhz coexistance channel width only on 2.4ghz.
The setting just tells the Orbi to back down to 20 mhz if it finds a competing wifi that it might interfere with.
There are a few cases where turning this off will improve 2.4 ghz performance. Whether that matters depends on what devices you have that require this band. Your phones, tablets, and pcs are almost certainly connecting at 5 ghz.
Ya, I know.
Ya most dual band devices prefer 5Ghz.
The best channels depend on your environment (particularly competing wifi), and also on regulatory restrictions in your country. Do you have a WiFi analyzer app (or PC software) that you can use to see competing signals?
I don't think you can change the channel width.
