JimS-CLT's avatar
JimS-CLT
Can't get my ios device to connect to Orbi 770 VPN.
I used the mobile device ovpn file vanilla except I changed the "verb" option to 3....
Here's my log file:
[Nov 17, 2025, 13:45:32] Connecting to************ via UDP
[Nov 17, 2025, 13:45:32] EVENT: CONNECTING
[Nov 17, 2025, 13:45:32] Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
[Nov 17, 2025, 13:45:32] Creds: UsernameEmpty/PasswordEmpty
[Nov 17, 2025, 13:45:32] Sending Peer Info:
IV_VER=3.11.1
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=8094
IV_MTU=1600
IV_CIPHERS=AES-128-CBC:AES-192-CBC:AES-256-CBC:AES-128-GCM:AES-192-GCM:AES-256-GCM:CHACHA20-POLY1305
IV_LZO=1
IV_AUTO_SESS=1
IV_GUI_VER=net.openvpn.connect.ios_3.7.2-6402
IV_SSO=webauth,crtext
[Nov 17, 2025, 13:45:32] SSL Handshake: peer certificate: CN=netgear, 1024 bit RSA, cipher: TLS_CHACHA20_POLY1305_SHA256 TLSv1.3 Kx=any Au=any Enc=CHACHA20/POLY1305(256) Mac=AEAD
[Nov 17, 2025, 13:45:32] Session is ACTIVE
[Nov 17, 2025, 13:45:32] EVENT: GET_CONFIG
[Nov 17, 2025, 13:45:32] Sending PUSH_REQUEST to server...
[Nov 17, 2025, 13:45:32] OPTIONS:
0 [sndbuf] [393216]
1 [rcvbuf] [393216]
2 [route] [192.168.1.0] [255.255.255.0]
3 [route-delay] [5]
4 [route] [64.0.0.0] [192.0.0.0] [192.168.1.1]
5 [route] [32.0.0.0] [224.0.0.0] [192.168.1.1]
6 [route] [16.0.0.0] [240.0.0.0] [192.168.1.1]
7 [route] [8.0.0.0] [248.0.0.0] [192.168.1.1]
8 [route] [4.0.0.0] [252.0.0.0] [192.168.1.1]
9 [route] [2.0.0.0] [254.0.0.0] [192.168.1.1]
10 [route] [1.0.0.0] [255.0.0.0] [192.168.1.1]
11 [redirect-gateway] [def1]
12 [route-gateway] [dhcp]
13 [ping] [10]
14 [ping-restart] [120]
15 [peer-id] [12]
16 [cipher] [AES-256-GCM]
[Nov 17, 2025, 13:45:32] PROTOCOL OPTIONS:
key-derivation: OpenVPN PRF
compress: LZO
data channel: cipher AES-256-GCM, peer-id 12
[Nov 17, 2025, 13:45:32] EVENT: ASSIGN_IP
[Nov 17, 2025, 13:45:32] **bleep**: preparing TUN network settings
[Nov 17, 2025, 13:45:32] **bleep**: init TUN network settings with endpoint: 104.139.20.***
[Nov 17, 2025, 13:45:32] Client exception in transport_recv: tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified
[Nov 17, 2025, 13:45:32] Client terminated, restarting in 2000 ms...
________________________________
It is resolving the correct WAN IP address (I put stars in after the fact to obscure my ip)
What's happening here (Note my firmware version is: V10.5.20.3_2.2.45
  • FURRYe38's avatar
    Is the Apple device only exhibiting this issue?
    Any other devices to check on this?
    What model Apple device is this?
    What iOS version do you have loaded on the Apple device?
    Has this been working at all or just started happening?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
  • I'm connecting with my iphone now. iPad had exactly same issues. iPhone is running ios 26.1.
    I can use my laptop to test, but i have to put it on another network and I need the Apple stuff to work for my upcoming trip where I won't have my laptop. Laptop later....
    iPhone 16 Pro
    Just setting it up now.
    I'm on Spectrum. Apple connected to AT&T network. Spectrum modem is PC20.
  • Using my old RBR50 router, I was able to use the vpn pretty straightforward. I changed to the 770 series a few months ago. Going on a trip soon and need vpn.
    • FURRYe38's avatar
      So this hasn't ever worked on the 770 series since you got it?
  • CrimpOn's avatar
    CrimpOn
    Is the OpenVPN Connect app the most recent? (version 3.7.2)
    It would be helpful if you could try a non-Apple device.
    Internet search for that error message seems to suggest putting a line in the configuration file ("ifconfig"), which does NOT appear in the smartphone.ovpn file that the Orbi generates.
  • FURRYe38's avatar
    Any progress on this?
    Can you get the debug logs from the RBR when this issue happens?
    What was the reason for changing to this value? "I used the mobile device ovpn file vanilla except I changed the "verb" option to 3"
    JimS-CLT​
    • JimS-CLT's avatar
      JimS-CLT
      Tech support asked me to upgrade my router to a higher (apparently not published) rev level. I just now got home. I'll do it now. ChatGPT suggested making the verb option 3 to get more detailed error messages.
      • FURRYe38's avatar
        This a FW version?
        Let us know if the issue continues.
        "--verb n
        Set output verbosity to n (default=1). Each level shows all info from the previous levels. Level 3 is recommended if you want a good summary of what's happening without being swamped by output.​
        0 -- No output except fatal errors.
        1 to 4 -- Normal usage range.
        5 -- Output R and W characters to the console for each packet read and write, uppercase is used for TCP/UDP packets and lowercase is used for TUN/TAP packets.
        6 to 11 -- Debug info range (see errlevel.h for additional information on debug levels).​" From openvpn.net for accruate information.
