PimpDiggler
Jul 03, 2025Guide
Continuously disconnects wifi connections with my Pixel 9Pro XL
I will be downgrading this version continuously disconnects wifi connections with my Pixel 9Pro XL is there a link to the 9.12 version before this I can downgrade to
- TOPS119Luminary
I have a 9 pro xl as well im not facing that issue on the new firmware... This might be something we need to look further into
I still have ipv6 enabled and it was enabled in the last firmware as well and I didnt see nearly the disconnects I am seeing since upgrading
Have you done a factory reset and setup from scratch after v.2 FW was loaded to see if problem still happens?
