Magicmomo's avatar
Magicmomo
Orbi 370 no internet
Orbi 370 cannot access the Internet in Germany with FRITZ!Box 7530 AX
Everything else in the setup with the app worked without any problems. Is this a known issue? Does anyone know of a solution?
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
    https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
    https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
  • CrimpOn's avatar
    CrimpOn
    Although Netgear is "on the bandwagon" with the trend toward using a smartphone app for almost everything, many customers find using the web interface more successful than using the Orbi app.
    The User Manual describes how to set up the router using the web interface:
    https://www.downloads.netgear.com/files/GDC/RBE373/RBE371_RBE370_UM.pdf
    The web interface provides a lot of information about the WAN port connection (to the FritzBox) that might be useful in diagnosing the problem.
    Does the Orbi app show:
    • The router to be connected to the internet?
    • That user devices are connected to the Orbi system?
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello Magicmomo ,
    Welcome to the NETGEAR Community!
    I understand that you are having issues with connecting your Orbi mesh system to the internet. This issue occurs when the ethernet cable is not connected to the ethernet port on your RBE370. Please be sure to connect the Orbi mesh router "WAN" port to your ISP ethernet port. You may need to replace the existing ethernet cable if the issue continues.
    Best,
    Kevin
    Community Team
