GatorMitch
Dec 22, 2025Aspirant
Orbi 370 Satellite Speed is bad
I thought I was upgrading from my RBR50 and 1 satellite that died by getting the Orbi 370 and 1 satellite. Wow was I wrong. I have 500 speed fiber. Wireless that sees the router gets great speed, same as my old RBR50. The satellite barely breaks 150 up and down. The RBR50 satellite would push at least 350 or more. The router and satellite are in the same exact locations in my house as the RBR50 was.
I did the install by the book and made no changes to the basic or advanced settings. Is the 370 just an inferior product? Are there settings I should change to get back to the speeds I had with the RBR50 satellite?
If this can't be resolved easily. I'm returning the 370 and tring another brand mesh system
- coolwifiLuminary
The Orbi 370 doesn't have a dedicated backhaul band and it's a cheaper base model. Meanwhile you could try different 5 Ghz channels (36-48 or 149-161) with 80 Mhz bandwidth to get better performance. The DFS channels have lower transmit power and impact the wifi range.
For more in-depth information. Dong did do a analysis on the orbi family, the MLO option, the backhaul option, and more. its worth a read if you want more information on the subject.
https://dongknows.com/netgear-orbi-overview/
Was the old 50 series slowing anything down or what triggered the desire to update? The 50 series should still be decent with 500mbps service.
- GatorMitchAspirant
My previous RBR50 router just stopped working. The white led kept flashing and would never connect.
Not sure if the backhaul to the satellite is 5g. I did the basic plug and play set up. I figured that would optimize the connections. Not sure I would check if the back haul is 5g. I recall my RBR50 had a beamoforming option, or something like that. I don't see that setting for the 370.
If you log into the web ui, and then look at "attached devices", you will see the satellite connection type (hopefully "5 GHz") at the top of the list. There's also a connection status (hopefully "good"). If the connection status is "config sync", then the mesh is still figuring out the best connection.
If your test client is near the satellite, you should also be able to see whether it is in fact connected to the satellite wifi, or whether it remains connected to the router. You can also see whether the connection is 2.4 ghz or 5 ghz.
Over time, some settings are removed simply because there is no reason for users to turn them off.
In any event, it is built into WiFi 7, so the 370 does have that feature.
The RBE370 is the most base model system without a dedicated backhaul. The RBK50 was the flagship at its time. Thats why. To see faster peak speeds, you'd need to upgrade more.
I'd take a look at Dong Ngo's review of wifi 7 mesh systems. Take a look at the performances and expectations as well as price. Then choose.
https://dongknows.com/best-five-wi-fi-7-mesh-systems/
He does review the lower end systems too so its worth checking those out if you're on more of a budget.
Thanks for the link. When I read the features for the 370 it says it has enhanced backhaul (MLO). Are you saying it doesn't have a dedicated backhaul to connect the satellite to the router? I can't figure out if any other similar priced set up has a dedicated backhaul.
It does not.
FWIW, high-end WiFi 7 routers have three client bands - 2.4 ghz, 5 ghz, and 6 ghz. They are trending away from a dedicated backhaul network, since the extra 6 ghz band adds enough bandwidth to allow running the backhaul over the same radios.
Is the backhaul to your satellite using 5 Ghz? Also, do you know what band the client is connecting with?
