john_j's avatar
john_j
Tutor
Dec 11, 2025
Orbi 870 -and Disney+ problems
Hi,
I replaced my Fritzboxes with an Orbi 870 Mesh and since then I have not been able to use Disney+:
  • Internet via Vodafone VDSL
  • Draytek Vigor 167 as modem (nothing configured, just plugged in and PPoE set in Orbi)
  • I have not configured anything else in Orbi, no Armor etc.
  • Disney apps iOS/tvOS give me an error #93 (access blocked, e.g. due to VPN (which is not the case)).
  • Login via browser results in ‘Sorry, an unexpected error has occurred. Please try again later.’
  • I can start Disney without any problems on another Wi-Fi network or via mobile data.
Someone here in the community wrote that you have to set iPV6 to DHCP, another said you should turn it off completely – I tried both without success. I'm at a dead end. Trying everything is beyond my patience (turn off, wait 2 minutes, start up the modem, wait, start up the router...). So I hope you have a tip for me.
Best regards, Heiko
  • OK, here`s the solution: I called Disney and the friendly helpdesk added my IP address to my account. Now everything works fine - let`s see how long, as the IP is not a static one.
    BTW - I don`t think that there could be a problem with the Modem ore double-NAT, as everything else works fine and doesn't show any signs of double-NAT.
    Thanks for your help - I will keep you informed, if anything changes.
    • FURRYe38's avatar
      Ya could be Disney and there security.
      Ya but if "Netflix, Amazon and Apple TV work fine" then kind points to Disney as sus. :oP
      Hopefully mostlly fixed for you. If it seems so, mark your thread as solved so others will know.
  • I think this problems are based on their attempts to avoid account-sharing.  But I have no idea what could have triggered this when changing modem/router. There have certainly been changes to the WAN IP here in the past. We will see...
    • FURRYe38's avatar
      Interesting. Will be interested to know if Disney keeps working or not past a WAN IP address change. Something on there side may have been causing problems.
  • OK here`s an update:
    • using 8.8.8.8 and 1.1.1.1 as DNS -> same error
    • putting an Apple TV into DMZ -> same error
    Netflix, Amazon and Apple TV work fine, btw...
    • FURRYe38's avatar
      Can you  check with your ISP to see if this model modem doesn't have any router built in, if it does, then ask them to fully bridge the modem?
  • plemans's avatar
    Some of those services don't play nicely with a double nat. The Draytek Vigor 167 is a modem/router combo device. you might try putting the Orbi into the vigor's dmz so its not acting as a router along with the orbi.
  • FURRYe38's avatar
    Does putting a PC or device in the RBRs DMZ change anything?
    What happens if you set the modem for PPPoE and it the modem handle the PPPoE connection, then change the RBR to use DHCP for the WAN side connection?
    Are you using ISP detected DNS or custome DNS on the RBR?
    I would keep IPv6 disabled for now on the RBR.
    What firmware version is on the Orbi system?
    • john_j's avatar
      john_j
      Tutor
      Thanks! Starting at the end - firmware is actual (V10.5.20.4_1.3.5). I will try the DMZ and DNS tomorrow. Setting the modem for PPPoE will be a little bit more complicated, but I will give it a try.
