OlaGarp
Apr 03, 2025Aspirant
Unable to install iPhone apps using Orbi RBE771
When connected to the RBE771 wifi, I'm unable to download and install iPhone apps. As soon as I turn the wifi off the mobile, the apps download and install.
Appreciate any help
Ola
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Who is your ISP service?
Does this happen with the RBS turned OFF?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, IPv6, Smart Parental Controls, Traffic Meter.- OlaGarpAspirant
Hi
Firmware: V10.5.13.1_2.2.34
Modem: NBNCo
Cable: CAT6
ISP: Internode
What is RBS?
Tested with and without WiFi Private IP address
Not using iCloud Relay
Not using Armor, IPv6, Smart Parental Controls, Traffic Meter.
Cheers
Ola
Let us know if changing the DNS recourse helps.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There should be a model# on the sticker. Trying to check for a built in router here.
RBS = Satellite.
OlaGarp wrote:
Hi
Modem: NBNCo
Cable: CAT6
ISP: Internode
What is RBS?
Cheers
Ola
- MiniTunaGuideDo you happen to be using AdGuard DNS or a similar service? For me, that was the cause of App Store brokenness / slowness so I switched to NextDNS. It's also possible your ISP is at fault. Try first by switching your device to known "clean" DNS servers like 1.1.1.1 or 8.8.8.8.
