llerrad321
Sep 16, 2020Aspirant
nighthawk ax4 does not recognize password on 5g
works password on 2.4, but does not on 5g
Do you have the RAX40?
What device is having issues?
all of them?
Certain ones only?
Did you change the password?
Make sure to remove any special characters/spaces from the password.
Also make sure capitalizationj is correct.
- llerrad321Aspirant
rax35,works on 2.4,but not on 5g on all devices
can i do a factory reset to make sure i didnt change any passwords
rax35,works on 2.4 but not on 5g on all devices
have you tried changing the password?
check for special charaters/spaces?
forgetting the ssid/password on your devices and reinstalling them?
You're not giving me a whole lot of info. help us to help you and fully describe issues, what you've done to try to fix it.
can i do a factory reset,and use the password that is on my router incase something was change
