Dustin_V
Dec 17, 2018NETGEAR Employee Retired
Nighthawk AX8 8-Stream WiFi Router - Buyer's Guide
With the influx of smart home devices on the market making their way into our homes, one thing we tend to overlook is the infrastructure that supports it. From smart speakers, security cameras, appliances, locks, and more, your home WiFi network needs to be able to perform efficiently to ensure a more enjoyable experience. This Holiday season may be a true test of how well your network can stand up to the challenge. Whether you’re hosting friends and family who’ll be bringing connected devices into your home or you're expecting to receive smart home goodies as gifts, the last thing you want is an underperforming network that is too slow and unreliable to get the job done.
Enter NETGEAR’s first AX WiFi router, the Nighthawk AX8. By using the latest Wi-Fi 6 standard (802.11ax), the AX8 will help future-proof your home and will improve network capacity for multiple smart home devices, old and new. Now, when your family comes to visit, you can proudly provide them guest WiFi access without feeling embarrassment about bogging down your network and being known as the family member with slow WiFi.
By touting features like Orthogonal Frequency-Division Multiple Access (OFDMA), you’ll experience improved network capacity, giving you more available bandwidth for more added devices to your network. As an 8-stream WiFi router, more WiFi streams will mean less congestion on your network and more reliable connections to all your connected devices. By being backward-compatible, not only will your current WiFi devices be supported, but all future AX WiFi-supported devices as well.
Whether you’re looking for more reliable smart home connectivity, smoother UHD 4K/8K streaming, or faster and farther coverage, the Nighthawk AX8 is here to proudly lead the new era of WiFi. If this isn't already on your Holiday wish list, now is the perfect to add it!
Learn more about the Nighthawk AX8: https://www.netgear.com/home/products/networking/wifi-routers/RAX80.aspx
Admin marked as SOLVED
- delkomanTutor
I recently purcased and installed AX8 in my home and had a very odd thing happen. When setting it up, I used the same SSID and password as the device being replaced. All of the wifi devices in our home connected to the AX8 execept my HP ENVY Laptop (purchased new in 2017). After qutie a bit of trial and error, I found that with the AX mode turned on, the PC did not recognize the SSID broadcast, With AX mode turned off, the router would show up as a wifi option. The laptop is running the latest version of Windows 10.
None of the other devices showed this behavior including Echo's, other Laptops, PS4, Mobiles, secuirity cameras, and IPADs. They all reconnected with AX turned on or off.
Any thoughts on how do fix this? I'd liek to benefit from the AX8's WiFi 6 AX mode.
- myerswMaster
Does the laptop support AX? I suspect not.
There are maybe one wireless hardware manufacturer that is making a chip that supports AX. AX is a coming down the road thing.
Folks let me know if wrong.,
- delkomanTutor
AX supposed to be backward compatible with all existing WIFI chipsets. The fact that I have a dozen or so older devices in my house that do not have the AX chip but DO see the SSID broadcas confirms the backward compatibility. It maybe the AX8 is only backaward compatible with some devices but not all and this needs to be addressed in an firmware update.
- OjagaInitiateI am having the same problem with Delkoman! I am so glad that you raised this issue here. I have submitted my case to Netgear and I am waiting for them to fix it.
Now what I need to is what effect turning off or turning on the AX mode have on the overall router, performance and all? Guys at Netgear, you need to attend to this ASAP because I spent some pretty dollars on this router and I am about to drop my review on it.- OjagaInitiateI forgot to add that everything in my home can see the WiFi But my Dell Inspiron 17 7000 series. This laptop has not failed me one day and now it doesn’t even see my brand new powerful router. Help!!
- fraczek12345AspirantCan you tell me if I buy 4 units of Nighthawk AX12 will they work as a mesh network or will I have any problems when moving with my phone between the during making calls on WhatsApp?
- Hi Netgear
How many concurrent devices can this support on the 2.4ghz band? Just wondering is it worth upgrading from my x6 R8000
Cheers
Eric
- BretDAdministrator
