JoeChillers
Feb 06, 2021Aspirant
No Internet Connection after Factory Reset
About a month ago, I bought a router to hook up to my modem. I used the Nighthawk app to help hook up the router and give off internet. The router worked well at the time. Just now I had to reset my internet connection although I accidentally factory reset my router because I held the reset button down for too long. I go to hook up the router again, but this time it says that my connection is secured but with no internet. I go back to the Nighthawk app to set up the router again, but they want me to scan the QR code from when I first bought the router that I no longer have anymore. I choose to set it up manually, but I end up with the same results: Secured, No Internet. I made sure cellular data was turned off when I tried connecting to the internet off my phone and the connection still gave me those exact results.
try factory resetting both the router and the modem.
What modem do you have?
You have the rax40?
- JoeChillersAspirant
Yes, the model is the RAX40
