HowardCoy's avatar
HowardCoy
RAX120v2 slow after tech support changes
I had the reboot issues with my router. Got the paid tech support. I’ve been on the phone with the very difficult to understand people almost daily. I no longer get the reboot issues but the router in 5G is very slow. My provider is rated at 500, speed test says I’m getting 75. My 2.4g is almost unusable. Every time tech support touches it, things get worse. I have the latest firmware update. Suggestions for fixing would be greatly appreciated.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. CAT6A STP if your using the MG port on the RAX Router.
    Are you using the Multi Gig port for the internet connection or the Yellow Internet port?
    Are you speed testing with a ethernet connected PC or wireless device? Ethernet is preferred for speed testing and accuracy.
    • HowardCoy's avatar
      HowardCoy
      My firmware is 1.2.9.52. The modem I use is one I purchased and used with my previous router. It is an Arris SB8200. I use CAT6 cable connected to the yellow internet port.
      • FURRYe38's avatar
        Can you explain what NG support did to the router?
        Armor, Smart Parental Controls or Circle, Traffic Meter.
        Has a power off for 1 minute then back ON with the ISP modem and router been performed?
        Turn off and unplug modem.
        Turn on computers and rest of network.
  • michaelkenward's avatar
    michaelkenward
    Was that the official paid tech support, or own of the cowboys out there who pay Google to post their misleading ads?
    Not without a lot more detail about what happens at your end.
    For a start, what are "the reboot issues"?
      HowardCoy
      In answer to your question. It is the “official” Netgear, over-priced tech support who are absolutely completely useless. The reboot issue has been addressed multiple times on this forum. The router would reboot multiple times while streaming. Now it doesn’t reboot but is almost useless after the official tech support “fixes”. I have no idea what the tech support team has done. They go in and make changes and say, “ now try it for a day.” My speed test is not made with an Ethernet cable since all my devices are wirelessly connected.
